It is currently Sun May 19, 2013 1:42 pm
 Post subject: biscayne 18
PostPosted: Sat Feb 16, 2008 7:07 am
I am experiencing some vibration from the shaft/propeller. I am quite sure that it is within normal limits. I am using a new Acme prop, the shaft has been checked for trueness, and the shaft/trans connection is perfect. I am using the $12 strut bearing and am wondering if the more expensive rubber bearing{$70} would make a noticable difference. I am also considering the R and D flexible shaft coupling. Anyone have any experience/opinions?Also,how difficult would it be to change the strut bearing myself? I do not have a special tool for this and would have to make one if anybody knows how. Thanks!
 Post subject:
PostPosted: Sat Feb 16, 2008 1:28 pm
Check your prop closely for any signs of pitting. That would be cavitation. Cavitation will cause vibration.
