Building Modified Importer
Geor
Post by Geor »
After looking for a commercial built camper and only finding campers that weigh 1000+lbs. I've decided to build my own. My Tacoma only has a 1300lb. load capacity and after passengers and gear that doesn't leave much. I want something smaller than a full cabover but more than just a shell. I've been camping this summer and sleeping in the back with the Leer shell and the 6' bed isn't long enough for me to sleep in comfortably, being 6'1".
This will be just tall enough for me to sit on the bunk without hitting my head on the ceiling.
rocker
Re: Building Modified Importer
Post by rocker »
Yes but does it float? :lol: :lol: :lol:
Looks great.
Geor
Post by Geor »
Sure, it'll float. :roll:
Geor
Post by Geor »
Lowka53
Post by Lowka53 »
8) you are getting there if the paper i seen in one of the photo tells me any thing you are in Utah what town. 8)
14' Mr John-being built
32' Supper Huck-in design
Rod H
Geor
Post by Geor »
I'm in Salt Lake County
Lowka53
Post by Lowka53 »
:lol: not to far away then from my location I am in Ogden :wink:
Rod H
Geor
Post by Geor »
Interlux Inter-Prime Wood Sealer Clear
Interlux Pre-Kote - White
Interlux Brightside - Black
Geor
Hello Dolly!
Post by Geor »
Waiting for the black goo to dry I built a dolly for the camper.
Geor
Post by Geor »
I'll be putting the first ceiling panel on this weekend.
Geor
Help bending panel needed
Post by Geor »
I'm trying to bend a piece of panel I got from Lowes, 5.0mm Utility Hardwood, and not having much luck. I've been soaking it with wet towels for about two hours now and it's not softening up. I'll probable have to get something else to work with. Any suggestions?
Geor
Post by Geor »
Sometimes you just gotta do it!
Used a ratchet tie-down to pull the panel down once the front was secured to the cabover deck.
slug
Post by slug »
Coming along quite nice. What are you planning for the outer skin?
Geor
Post by Geor »
I'm going to check out some trailer repair shops in the area to see what's available and what they suggest, but I think it will probably be aluminum. My #1 priority is weight. I may just get a couple quotes on having one of them do it.
dan8089
Post by dan8089 »
lookin' good any updates?
Return to “Glen-L RV's”
