Corrugated fasteners
Monte48
Post by Monte48 » Sat Dec 01, 2007 4:19 pm
Monte48
Photos
Post by Monte48 » Sat Dec 01, 2007 4:23 pm
This isn't working
[img]<a><img></a>[/img]
Nova SS
Post by Nova SS » Sat Dec 01, 2007 4:36 pm
I'm not sure how it works with Ringo but I use photobucket as my photo host and it seems to work pretty good
Dave Grason
Post by Dave Grason » Sun Dec 02, 2007 4:32 am
Ok Monte, I went to the Ringo photo site and I can get it to work. Here's the final secret. You have to expand the thumbnails until they are the ONLY thing on your screen and THEN copy the URL. But I can't find your particular photos without your giving me a password. But I did find this off the Ringo site to use as an example:
steve crawford
Post by steve crawford » Sun Dec 02, 2007 8:20 am
I made an air actuated pocket hole machine years ago .Has 2 air cylinders
and used for all face frames.
I should post pics. of it.
If using dowells I sugest pipe clamping the joint together and then (with a pin nailer) shoot 1/2'' pins from the back side into the dowel on each side of the joint. The pins will hold the joint tight so you can remove the clamps to use somewhere else.
If you don't have one of those pocket drill systems use mortise and tennon joints.
Cabinet doors use this type and shoot 1/2'' pins in the joint on the back side.
But joints are fast but not structual.
Return to “Glen-L RV's”
