1/2 ton pu with 6 1/2 ft. Bed.
Hoss
Postby Hoss » Sat Aug 19, 2017 2:49 pm
I want to build a 8 foot slide in camper and put it in a pu with a 6 1/2 ft. Bed with the tailgate down. Is there a problem with this?
Mr Hot Rod
Re: 1/2 ton pu with 6 1/2 ft. Bed.
Postby Mr Hot Rod » Sun Aug 20, 2017 3:31 pm
Welcome to the Forum, Hoss !
Tell us a bit about your truck's engine, transmission, gearing and payload capacity. As a general rule, the camper's CG (Center of Gravity) must fall within the rear wheel's leading and trailing edge.
More info below. Scroll down to item # 6, COG (Center of Gravity) :
The link below is a list of dimensions which can be used to determine if the camper you are interested in will fit you truck without modification to the plans and patterns :
See our website's Video Directory for links to RV Build Websites and Photo Albums.
____________________
Paul Kane
Kane Custom Boats Ltd.
Chelsea, Quebec
Glen-L Hot Rod build thread
Glen-L Boat Video Directory
Return to “Glen-L RV's”
