plywood for the walls
chris-d
Post by chris-d » Sat Feb 27, 2010 7:37 pm
I ended up buying 17 sheets of 1/4" okume plywood for the walls. The plans call for 3/8" interior to suit.
I began thinking, this wood is very flexible, it bends real easily, is this not the best wood i can use for my trailer?
does anyone know if I can use okume plywood for the walls or has any informaiton on okume?
upspirate
Re: plywood for the walls
Post by upspirate » Sat Feb 27, 2010 8:04 pm
Chris,plywood seems very flexible(it is actually) but when used with framing or as a structure it is very strong.
If the B.O.M. calls for 3/8 though, 1/4 may not be strong enough
chris-d
Post by chris-d » Sun Feb 28, 2010 5:20 pm
Thanks, I meant 3/16ths but i typed it in wrong
so I guess I'm ok then .
Return to “Glen-L RV's”
