Fisherman
Re: Fisherman
Post by Bill Edmundson » Tue Apr 02, 2019 1:01 pm
Eric
I usually work alone. Working the whole side as one big panel won't happen. I put the first sheet, then clamp screw and glue the backer piece. Once the glue is set, I bolt screw and glue the next panel. The bolts help bend the new panel to match the rest of the splice. Bolts are removed and the holes filled.
Re: Fisherman
Post by DrBryanJ » Tue Apr 02, 2019 2:32 pm
I did the same as Bill. I found that when I was fairing the panel later that the joint was amazingly fair already. Very little tweeking needed.
epiziali
Re: Fisherman
Post by epiziali » Tue Apr 02, 2019 3:13 pm
Thanks guys, that answers my question.
Eric
epiziali
Re: Fisherman
Post by epiziali » Tue Apr 02, 2019 4:33 pm
Hi Bill.
Do you by chance have a pic with the bolts installed? Trying to envision the steps you are taking.
Thank you.
Eric
Re: Fisherman
Post by Bill Edmundson » Tue Apr 02, 2019 5:49 pm
Eric
Sure don't have that picture. It will depend on your bend. Usually I would start in the middle and work out.
Evan
Re: Fisherman
Post by Evan » Thu Apr 04, 2019 11:40 am
I used both methods on my boat. The method described above by Bill is much better.
I joined the sides using fiberglass tape before mounting them. You have to keep them flat and from moving a PIA by itself.
It also takes a long time, I did both sides so I had to wait for the epoxy to cure before I could move it. I usually only have short periods to work on the boat, using this method there was a few minutes and then I was done.
I found that the real problem was that you now have a large area to fair. Although the glass is thin and there were no wrinkles there is fairing to be done along both sides of the tape.
I used the method described by Bill on the deck. The butt joined perfectly, I don't think there is any fairing to do but if there is it will just be one line where the join is.
The deck where is did the join has quite a curve in it, the wood will bend no problem.
epiziali
Re: Fisherman
Post by epiziali » Thu Apr 04, 2019 9:43 pm
So I was thinking I could clamp a scribed 2x4 against sheer ply and a block on the back side. Seems to hold the backer piece in tight.
Repeat with second sheet once first sheet is secured / glue is dry.
Eric
Re: Fisherman
Post by DrBryanJ » Fri Apr 05, 2019 5:23 am
epiziali: That look like it will work out fine.
Re: Fisherman
Post by PeterG » Fri Apr 05, 2019 9:03 am
What a great method, works on both sides of the joint and both sides of the boat. This goes into my notebook for my build :)
epiziali
Re: Fisherman
Post by epiziali » Fri Apr 05, 2019 8:31 pm
Thanks guys. Once again the forum provides courage. 👍
Eric
epiziali
Re: Fisherman
Post by epiziali » Sat Apr 06, 2019 10:56 am
I am not seeing much specifics on screw pattern for backer. The book called for every two inches. Is this at the seam only? Or throughout? I am almost inclined to Glue and use no screws. The screws are holding two pieces of 1/4 inch plywood together. So not much there for the screw to hang onto.
Eric
Ibrew2be
Re: Fisherman
Post by Ibrew2be » Sat Apr 06, 2019 5:47 pm
That's sort of the way I thought about it, too. Granted, my boat is smaller than yours, but I didn't bother with screws in the butt blocks on the sides. After 4 seasons on the water, no problems.
Barry
Barry Shantz
Imp built and launched. Thinking hard about Boat 2.0
epiziali
Re: Fisherman
Post by epiziali » Mon Apr 15, 2019 11:21 am
I wanted to loop back on my butt joint. I think I ended up doing what Bill does. The blocks were an effective way to clamp the backer and hold tight to screw the sheer into. But at the seam, I needed more clamping strength than I could get out of my blocks. So I ended up bolting.
Bill, wondering if this is what you meant, see pic. Also, what did you use to fill holes. I was thinking I would use epoxy and dowel.
Eric
Eric
Re: Fisherman
Post by Bill Edmundson » Mon Apr 15, 2019 12:34 pm
Eric
I think I just used 1/4" bolts and filled with thickened epoxy. I was always planning to paint anyway.
