jwputnam wrote:
The cut in the stem is EXACTLY as per the plan. It indeed starts the keel upward. Any builder following the plans would have to assume that this is intentional for one reason or another.....otherwise, why draw it that way? It would be quite easy to make it level.
Again, I believe that it will fair out.
I don't think the cut is the issue as much as if your transom is set up too upright. The keel and even any battens and chines will be pushed upward towards the sky if the transom is not set at the appropiate angle or even the correct height in the alignment portion of the setup. Few boats have hooks built into the bottom. And for sure adding back a lot of fill should not be part of the build and the work that goes into creating a fair line begins in the jig portion of the build and setup. If the transom is set per plans the take a good look at the other stations. I took a quick look at the builders photos section and found these jig skeletons. I do not see and hooks or dips in them. Take a look at the same photos and simular angles thats a good sampling of other builds that Bill posted if you missed them. The bottom appears to be fair in its building stage. The fondation of any boat and its performance issues begins at the building stage and is key to create a happy "camper" on the water.
