It is currently Fri May 24, 2013 6:42 am
Post new topic Reply to topic  [ 289 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14, 15, 16 ... 20  Next
 Post subject: Re: Sawford's Zip Build
PostPosted: Tue Jun 26, 2012 6:33 pm
I had always envisioned a polished cutwater...I'll have to see what to do....
Just curious, regarding speedometers...do most people now go with a gps version? The other option is to run a pitotube or water wheel....does that go through the hull, or do you run something over the side? I prefer not to do that. I was just pricing gauges and have some sticker shock!
PostPosted: Wed Jun 27, 2012 4:38 am
I went with the Teleflex GPS Speedometer. It works well but the speedo head and receiver run about $300.00 Besides speed you get a digital compass heading readout.
PostPosted: Sun Jul 01, 2012 5:27 pm
Built the seat bases and backs, started with the side storage compartments (arms rests) and the recess for the control box. Also ordered instruments (w/ gps speedometer), battery box, on board charger, bilge pump, fuse panel, switches, and miscellaneous hardware. I have a 'to do' list a mile long so I will just keep plugging away.
File comment: here, on top of the boat (i.e. work bench), I am working on the arm rest/recess for the control box
PostPosted: Sun Jul 01, 2012 7:36 pm
Nothing better than a long list of tasks and all the parts in stock. Keep pluggin'
My Zip build log...
PostPosted: Mon Jul 02, 2012 4:25 am
Coming along nicely!!!
Roberta :D :D :D :D :D
PostPosted: Mon Jul 16, 2012 5:58 pm
I was on vacation since July 3rd and out of town for a lot of that time. As such, not too much time to spend on the boat. Over the past couple weeks, I have:
1. roughed out the motor well (it's done, but needs 'finished'),
2. added some extra reinforcing to the transom (i.e. some kickers from just below the motor well to my bottom seat beam that ties to keel/battens),
3. finished roughing out the armrests (they could be complete but I think I am going to add some removable inlaid 'covers' out of a contrasting wood that will allow for access into the compartment).
4. roughed out the soul in front of the dashboard
5. realized that the dashboard is not deep (wide) enough to accommodate the steering unit. As such, I added another piece of white oak below the dashboard to lower the dash by another 1 1/4". I am going to cover the dashboard with a 1/8" solid walnut piece anyway, so the seam between the original frame and the scabbed on peace will not be visible. I just wished I had realized that when I was building the frames to begin with.....but experience is something we don't have until after we need it.
My next steps should be to cover the dash, cut out the holes for the instruments, begin to install the elect/mechanical systems, and then continue with a "boat load" of interior finish work.
File comment: rear seat and armrest
File comment: motor well and if you look close enough, you can see the additional kicker down to the bottom seat support beam
File comment: armrest with recess for control box...drilled, nuts epoxied in place on back side...box bolts right in
PostPosted: Mon Jul 16, 2012 6:09 pm
Making great progress and looking good.
My Zip build log...
PostPosted: Mon Jul 16, 2012 6:24 pm
Look's Great!!! Should be ready by G6!!! :wink:
Roberta :D :D :D :D :D :D :D
PostPosted: Sun Jul 22, 2012 3:49 pm
I overlaid both dashboards with 1/4" black walnut and then installed the steering helm and roughed in the instruments. The walnut will be much darker once it is encapsulated/finished. That's it for now....
PostPosted: Sun Jul 22, 2012 6:40 pm
I really like those gauges. Look forward to seeing the dash pop when the finish is put on it.
My Zip build log...
PostPosted: Wed Jul 25, 2012 6:17 pm
I did a good bit of epoxying (if that is actually a verb??) and couldn't do too much on the boat during the cure so I decided to make one of the side panels that will go above the armrests against the hull. I have the other three panels cut, but just need to cover. No rush on those, don't actually need them until the very end....
PostPosted: Sun Jul 29, 2012 5:51 pm
Spent some time running wires, connecting instruments, fuse panel, switches, hooking up the pumps, installing battery box/battery. Just for fun, I connected the motor, control box, and battery...turned the key and turned the motor over. No fuel or cables hooked up, but at least it turned over! Also tried the lights on the instruments and they fired up too. I didn't run the lead-ins to the instruments yet (i.e. fuel, tach, speedometer), but I'm getting there.
PostPosted: Sun Jul 29, 2012 7:04 pm
The wiring is a fun change of pace in the build process isnt it? Its not sticky or dusty and its a kick to bring your boats components "to life" the first time.
My Zip build log...
PostPosted: Mon Jul 30, 2012 5:03 pm
Agreed. It is a good, clean, change of pace.....now I'm not too far from beginning the deck!
PostPosted: Sat Aug 04, 2012 3:59 pm
couldn't resist getting a sneak peak of the interior.....installed 2nd pump (one for each side of keel), switches, cupholders, steering cable, gas line, motorwell drain tube. also started painting the boot strip. now I'm getting real close to the deck...
