It is currently Sun May 19, 2013 1:59 am
Post new topic Reply to topic  [ 284 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15, 16, 17 ... 19  Next
 Post subject: Re: Sawford's Zip Build
PostPosted: Sat Aug 04, 2012 4:02 pm
And in our spare time, we decided to build a second boat....made from left over OSB and epoxy! maybe a marine battery and a trolling motor are in order (ha ha)!
PostPosted: Sat Aug 04, 2012 4:45 pm
Look's Great!!! Smart idea to do the wiring and plumbing before the deck goes on. I protected everything with masking tape and wax paper so adhesives would not ooze onto the gauges and wiring when I laid down the decking. Kids look like they are anxious for you the finish the big boat. :lol:
Roberta :D :D :D :D
PostPosted: Sat Aug 04, 2012 5:23 pm
It is MUCH easier to do wiring and plumbing before the deck goes on :!:
PostPosted: Sun Aug 05, 2012 5:01 am
Interior looks great! Kids look like there having a great time . Once the boats complete get the tube out!!
Travis
Measure Twice, cut Once.
PostPosted: Tue Aug 07, 2012 4:03 pm
Added the boot stripe, which took a week plus, from the time I started taping, two part primer, and four coats of brightside. Just added the ski hook / tie down anchors. I always hate drilling holes in a perfectly good boat!
PostPosted: Wed Aug 08, 2012 4:36 am
Looks nice!!! I cheated and used striping tape and buried it in the clear topcoat.
Roberta :D :D
PostPosted: Wed Aug 08, 2012 9:50 am
I thought about using pin striping as well but then wasn't sure how to 'imbed' the stripe. Roberta, since on topic, what did you clear your boat(s) with? I was thinking of epifanes clear varnish.
PostPosted: Wed Aug 08, 2012 10:05 am
I know many people who have used epifanes with great results, but it really reeks with fumes. I chose System Three WR-LPU water based paints and clears. They roll on easily and do not smell. Water cleanup and water reduced. The trick with WR-LPU is to roll it on as thin as possible, do not overwork the stuff or reroll, keep a wet edge, and make sure humidity is around 50% or higher. You can recoat in about an hour and recoat as many times as you want in a day. Recoating must be done within 24 hrs to get a chemical bond. Wait a few days if you need to sand out any runs or curtains, but, you should not have any if you roll thin coats. Also mix new batches with every coat and wash out the roller for the next coat.
PostPosted: Sun Aug 12, 2012 5:29 pm
Thanks for the information....I ordered a gallon of System Three WR-LPU clear gloss. I like the idea of water clean up and water thinning. I read some reviews about difficulty with applying in low humidity conditions. That typically isn't a problem where I live, so I'm not concerned.
I added the plywood subdeck this weekend. I had one full sheet plus a bunch of miscellaneous scraps of hydrotek leftover from the hull. I originally ordered 7 sheets (8' x 4') and it turned out I used pretty much all of it for the hull and deck. For anyone else out there planning a zip, 7 sheets should be just what you need.
PostPosted: Wed Aug 15, 2012 5:14 pm
Finished sanding the edges of the plywood subdeck yesterday and started 'eyeing up' the mahogany deck layout. Looks like it should be fun!
PostPosted: Wed Aug 15, 2012 6:36 pm
This is the fun part :!: It's hard to stay out of the shop :!: :) :) :)
PostPosted: Tue Aug 21, 2012 5:06 pm
I agree! Lots of fun now. While waiting for epoxy to cure i started to tinker with the interior seats. Not too much progress but no rush either.
PostPosted: Thu Aug 23, 2012 5:14 pm
looking really nice!!!! I'm anxious to see updates, as it seems you are at the place where it starts really coming together!!!! congrats on the progress so far!!!!
If I had a dollar for every time I finished building this boat in my mind, I could afford to.... build this boat!
PostPosted: Sat Aug 25, 2012 5:11 pm
Thanks for the compliments!
I just finished the coverboards. I used a belt sander to get them close to the hull and a palm sander to finish. A lot of sanding and my belt sander is big and heavy. Since you need to sand with the sander partially upside down it really gives the forearms a workout.
PostPosted: Sat Aug 25, 2012 7:25 pm
That looks great! Marking and cutting that inside curve was a stressful step for me but it looks like you got it no problem.
I will pass on some good advice I got from Dave Lott, when it comes time to fair the top of the deck after its all installed use the belt sander as little as possible and switch to the random orbit sander as early as possible. It will save you some gouges and big scratches that take a lot of time to remove.
Looks like its about time for the king plank! Keep up the nice work, almost there!
My Zip build log...
