It is currently Tue Jun 18, 2013 11:28 pm
Post new topic Reply to topic  [ 3 posts ]
 Post subject: Homemade bench seat
PostPosted: Sun Jan 29, 2012 11:17 pm
I am planning on making a benchseat for my squirt because nothing i have seen advertised would work and because i figure, i have made everything else why stop now?
I was wondering if someone with experience could explain the process and provide any usefull links or advice they might have/
I have found the site veada.com which seems to have some good material
Also what thicknes of foam is recommended?
Thank you
 Post subject: Re: Homemade bench seat
PostPosted: Mon Jan 30, 2012 5:55 am
When I was thinking about a bench seat for my Squirt I built a rectangular base out of oak framing and planned to tie it in to the chines as in the plan diagram. It calls for the a 14 inch deep seat. If you follow the chine line and use standard 1" stock it will work fine. For the seat back you should plan to either hinge it for access or block across the aft end of the bottom and add tabs to inset at the bottom so you can lift the bak out. I ended up buying bucket seats; but I would most likely rethink that idea as the 3.5 inch thickness was a little more than I should have used. I would go with 2 inch or less thickness on the seat cushions or just use a 1/4 or 3/8 inch plywood panel. I have posted a pic of my original idea. I hope this helps.
PostPosted: Mon Jan 30, 2012 9:05 am
Whatever method you use for your seat, make sure you put enough rake in the back. We set our Zip's seatback at around eight degrees off of vertical, and if I had it to do over I'd go with 12 degrees. Just my two cents...
-Mark Shipley
