A Texan Tubby Tug Build
Trackhappy
Re: A Texan Tubby Tug Build
Post by Trackhappy » Tue Jul 28, 2015 3:02 pm
Sanding sometimes seems like a chore, but at this stage of the build I found it neat to smooth out the structure that you have built with your own two hands until she is beautifully finished. Looking fantastic!
geneanthes
Post by geneanthes » Sun Aug 23, 2015 7:09 pm
First coat of primer on! Scrubbed the hull good with a scotch brite pad, soap, and water to get rid of any residual amine blush. Last coat of epoxy was applied 3-4 weeks ago so the out gassing should be done. Made sure to rinse the soap off well and then used Interlux 333 for a final wipe down before applying the primer. Thought about thinning the primer but chose not to after I opened it up. Just made sure to put a thin coat on. Used a foam roller. So far, it seems to be working. As always, I appreciate any tips.
Me: GeneAnthes.com
My day job...Criminal Defense Attorney in Austin: GBAFirm.com
Tubby Tug Build: Taylor's Tug
Post by vupilot » Sun Aug 23, 2015 7:30 pm
Sweet!!! Really enjoy your updates. I really want to build one of these soon. Hope I can find the time before my boy would outgrow it. Just keep sanding! Its worth the extra hours of sanding now rather than later.
Dave Grason
Post by Dave Grason » Sun Aug 23, 2015 11:22 pm
So Gene, will you and the family be able to bring the tug to the Gathering?
Looking FANTASTIC BTW
geneanthes
Post by geneanthes » Mon Aug 24, 2015 5:43 am
I want to go so bad Dave but my schedule won't allow it this year. I really want to meet some of the other builders and see their work.
Me: GeneAnthes.com
Dave Grason
Post by Dave Grason » Mon Aug 24, 2015 5:51 am
I fully understand about schedule conflicts. I didn't make last year's G and it was the first one I had missed out of ALL of them. So, there goes my perfect attendance record. :oops:
I know it's quite a long drive from Austin but I do look forward to seeing this boat then at G10. I want to get a photo of it alongside Bill's new Bartender 7.3. (Bartender 24 :lol: )
If there is one aspect of the Gatherings that makes the trip worthwhile, to my thinking anyway, it's the inspiration boat builders receive from seeing all the other projects.
Post by mrintense » Mon Aug 24, 2015 9:14 am
Looking great Gene,
It's good that you waited several weeks before painting. It also sounds like you did the necessary preparation before applying the paint. Like you, I would like to get to the gathering at some point. For me its more of a matter of costs and less of scheduling although that is definitely a factor as well.
Good work and I am looking forward to seeing the finished boat. I am sure your daughter is as well.
geneanthes
Post by geneanthes » Sat Aug 29, 2015 12:05 pm
Thanks for the response! I really enjoy your blog Carl.
Woke up at 3:00 this morning to put another coat of primer on. Weekend time is limited so I have to make the most of it! Hope to be doing a little sanding this evening.
Me: GeneAnthes.com
geneanthes
Post by geneanthes » Sat Aug 29, 2015 4:43 pm
Warms temps means I can get started on my sanding and fairing. Of course, it's pretty gross when sweat pools in my respirator.
Me: GeneAnthes.com
Post by chugalug » Sat Aug 29, 2015 5:02 pm
:D Looks really nice.What's the finish color? and what color for the guts? :D
geneanthes
Post by geneanthes » Sat Aug 29, 2015 7:49 pm
Thank you sir! Flag blue on the hull and top. White inside. Planning on a faux teak floor a la SeaDeck Marine.
Me: GeneAnthes.com
geneanthes
Post by geneanthes » Sun Aug 30, 2015 10:45 am
After MUCH sanding, the hull feels fairly fair (see what I did there). There were a few low spots that needed more fairing compound.
Me: GeneAnthes.com
Post by vupilot » Sun Aug 30, 2015 3:00 pm
Its dusty, sweaty work but its gonna be so worth it when the final paint comes out smooooth.
Post by Roberta » Sun Aug 30, 2015 3:28 pm
Look's Great and I bet your daughter is turning inside out in anticipation!!! :lol: :lol:
Roberta :D :D :D :D
Dave Grason
Post by Dave Grason » Sun Aug 30, 2015 5:36 pm
May I ask, what are you using for fairing compound?
