It is currently Wed Jun 19, 2013 3:16 am
Post new topic Reply to topic  [ 9 posts ]
 Post subject: Zip Trailer
PostPosted: Fri Apr 27, 2012 9:11 am
I need to buy a trailer for the Zip I am building. Which type is recommended?
 Post subject: Re: Zip Trailer
PostPosted: Fri Apr 27, 2012 12:04 pm
I believe it would be the consensus that you should use a bunk trailer. You can build one from GlenL plans.
PostPosted: Sat Apr 28, 2012 8:12 am
After finding nothing but junky used trailers I bit the bullet and bought a brand new Shorelander SLV-15. Its works pretty well, it would work better when re-loading the boat if I had installed a bow eye in the stem but the cutwater is in the way of doing that.
My Zip build log...
PostPosted: Sun Apr 29, 2012 3:21 am
Don't know your location, but here are two used ones....the add shows trailers,and two registrations, so not sure if price is for two, or one
More than likely just the top one now that I re-read the add
http://cgi.ebay.com/ebaymotors/1990-Sun ... 19d0601fb8
PostPosted: Sun Apr 29, 2012 6:42 am
Those would work but his price for a 1990 trailer is the same as I paid for a 2009 trailer with upgraded 13" wheels and tires. Are galvinized trailers worth that much more than painted?
My Zip build log...
PostPosted: Sun Apr 29, 2012 6:46 am
Depends where you launch.....in salt, it's not worth it to have a painted trailer
PostPosted: Sun Apr 29, 2012 8:53 am
Well sure if you need it its more valuable to you but if identical trailers are sitting at the same dealer one painted and one galvinized was the galvinized one more expensive to manufacture thus commanding a higher price? Not something us midwesterners have any experience with. Just interested to know.
My Zip build log...
PostPosted: Tue May 01, 2012 9:25 am
Even in fresh, the painted will eventually rust, but you can deal with a sand and repaint every so often.
I personally like a painted trailer with pin stripe accents, but have to go for the longevity here!
PostPosted: Tue May 01, 2012 9:40 am
Many thanks for all you comments. I will start shopping...
Users browsing this forum: Google Feedfetcher, Mojo and 1 guest
