It is currently Mon May 20, 2013 11:16 pm
Post new topic Reply to topic  [ 7 posts ]
 Post subject: Tubby tug build thread
PostPosted: Mon Jul 02, 2012 9:54 am
In an attempt to document my work, I am starting a build thread.
1. session I cut the bottom of the boat.
First hanging the pictures of the details on the wall of my workshop
File comment: Details sheets on wall
The final bottom cut out of 3/8th inches plywood.
File comment: Bottom cut out
2. this session I cut all the minor parts including the sides and bulwarks (I am still missing a few bits and pieces)
* EDIT: I changed the picture as I realized I had a better one with all the parts.
Progress descriptions on my own site
1: http://plansforanything.com/?p=104
2: http://plansforanything.com/?p=126 most plywood cut
File comment: All parts laid out
PostPosted: Mon Jul 02, 2012 1:30 pm
Nice Work!! Keep posting!!
Roberta :D :D :D
PostPosted: Mon Jul 02, 2012 7:17 pm
Cool! I would be very interested in knowing how many hours this build takes you also. Will be watching!
My Zip build log...
PostPosted: Mon Jul 02, 2012 10:25 pm
So far I have spent 8 hours cutting the plywood parts -I keep a log of all hours I spend on this project (It's hidden from my girlfriend ;-))
I have no experience in building boats, and I normally spend 8-10 hours a day managing a group of software developers - so my assumption is, that I will use double the time compared to someone who has built a boat before.
As for the plans, I am totally satisfied. Everything is easy to understand and the full size patterns makes it a breeze to transfer to the plywood. For curves I usually nail a few pins through the paper into the sheet goods. Then I check with a batten, that I can recreate the curve. The it's just a matter of removing the plan and drawing up the lines.
/Søren
PostPosted: Thu Jul 05, 2012 11:52 pm
At 10 hours spent now - and I had my first glimpse of the shapes of the boat. See the pictures below :-)
File comment: Dry fitting the first side
File comment: Dry fitting the side
I haven't glued anything yet. I have been holding back, until I could do several things at one time to save epoxy.
Next on my agenda is to coat the parts with epoxy and mount the bulwarks in the boat - and then fit the two sides.
http://plansforanything.com/?p=135
PostPosted: Fri Jul 06, 2012 9:34 am
Grakan,
Looks really great so far! The TT is a real gem of a design.
As you are joining the sides to the bottom sheet, be sure the bottom stays absolutely flat. Mine developed a slight concavity which required some filling and sanding to correct.
Regards,
Steve Hansen
PostPosted: Tue Jul 17, 2012 12:06 am
Today I dry fitted the transom and stern seat.
Total build time: 12 hours
Users browsing this forum: Bing [Bot], Exabot [Bot] and 1 guest
