Utility build
Re: Utility build
Post by PeterG » Sat Aug 18, 2018 1:20 pm
Nice recovery, looks great!
Re: Utility build
Post by hoodman » Sat Aug 18, 2018 2:17 pm
Nicely flared!
Re: Utility build
Post by DrBryanJ » Sat Aug 18, 2018 3:39 pm
Nice job Michael! How did you flare them?
BarnacleMike
Re: Utility build
Post by BarnacleMike » Sat Aug 18, 2018 6:52 pm
Thanks, everyone! I used TONS of thickened epoxy, so I'm praying it won't leak. I made a heck of a mess... took forever to clean it up.
Bryan, I got the flaring tool that Matt offered a couple of pages back. It did a fine job, I thought.
It took a bit more force than I expected in order to make the flare. I used Moeller brass tubes, which are made from thicker / heavier material than the Seachoice tubes, though not as nicely polished. The heavier material no doubt made the flaring a little more difficult. However, it wasn't hard. I just used a socket wrench on one side, and a big combination wrench on the other.
Very anxious to put it in the water now to check for leaks.
-Michael
Re: Utility build
Post by hoodman » Sat Aug 18, 2018 7:12 pm
Mike, it won't leak as long as you remember the plug!
Re: Utility build
Post by mrintense » Sat Aug 18, 2018 7:28 pm
Sounds like a nice recovery Michael. I am sure t will be fine. Even if it does leak, it's likely to be very small and easily fixable.
BarnacleMike
Re: Utility build
Post by BarnacleMike » Mon Aug 20, 2018 7:05 am
Not "out of the water" on this project just yet...
But at least they work.
-Michael
Re: Utility build
Post by hoodman » Mon Aug 20, 2018 8:01 am
Looks like they've always been there to me!
Re: Utility build
Post by Bill Edmundson » Mon Aug 20, 2018 8:15 am
On an old boat we once had, I put the plug in from the inside. If you took on water, rain, wave or whatever, running down the lake you could pull the plug and drain it.
BarnacleMike
Re: Utility build
Post by BarnacleMike » Sun Aug 26, 2018 6:10 pm
Finished up the touch-up paint on the interior today (well... for the drain tubes, anyway).
Plenty of clearance behind the bilge pump for the starboard plug. Now I've just got to water test it.
-Michael
BarnacleMike
Re: Utility build
Post by BarnacleMike » Sat Sep 01, 2018 4:44 pm
Took the boat out today. The plugs are watertight. No problems whatsoever.
-Michael
Re: Utility build
Post by Hercdrvr » Sat Sep 01, 2018 5:28 pm
You’ll never go back to a boat with no drain plug. Good addition to your boat and a good fix on the little drill bit slip.
