Screw Lube?
Mrlew
Screw Lube?
Post by Mrlew » Mon Sep 02, 2013 3:17 pm
Gotta be careful with that subject :oops:
Didn't know if I should post here or in "Fasteners" but since I'm building a Sissy Do.........
What do you use to lubricate wood screws to make driving easier and stripping less likely? I've heard some folks using common Ivory soap but I've also read that soap is hydroscopic (attracts water) and can cause issues later. I have found that silicon/bronze screws, even with frearson heads, do have a tendency to strip if you've not very careful and figure a little lube could go a long way.
Chris
polarisman14
Re: Screw Lube?
Post by polarisman14 » Mon Sep 02, 2013 3:36 pm
I believe you can use ski wax or equivalent.
Re: Screw Lube?
Post by Bill Edmundson » Mon Sep 02, 2013 6:33 pm
I just use bar common soap. Deodorant is not needed.
rbrandenstein
Re: Screw Lube?
Post by rbrandenstein » Mon Sep 02, 2013 6:52 pm
My dad, who was a carpenter by trade, used liquid dishwashing soap. Keep a small cup of it and just dip the screw tip in it.
Also, I was having trouble with the SB screws breaking as I was fitting the planking, etc. So, as suggested somewhere in the forum, I used normal steel screws to fit the panel, and then substituted the SB screws when it was epoxied into place. The steel screws created a preformed hole and allowed the final screw to go in without breaking.
________________
Bergy
Re: Screw Lube?
Post by Bergy » Tue Sep 03, 2013 3:39 am
Akempucky works great. Sold by Jamestown Distributors and others I'm sure. Here is a link to Jamestown site.
http://www.jamestowndistributors.com/us ... o?pid=1184
"It's not the years in your life that count. It's the life in your years."
Abraham Lincoln
Mrlew
Re: Screw Lube?
Post by Mrlew » Tue Sep 03, 2013 5:06 am
Bergy wrote:Akempucky works great. Sold by Jamestown Distributors and others I'm sure. Here is a link to Jamestown site.
I looked into Akempucky a while ago, unfortunately it is no longer made. The Jamestown link says "no longer available".
I've heard bees wax is better than soap.
Bergy
Re: Screw Lube?
Post by Bergy » Tue Sep 03, 2013 7:01 am
Oh no! And I was about to order more. There is another product called Screwwax sold by Woodcrafters and Amazon. Looks to be the same as Akempucky.
Howard
Abraham Lincoln
Mrlew
Re: Screw Lube?
Post by Mrlew » Tue Sep 03, 2013 8:27 am
Bergy wrote:Oh no! And I was about to order more. There is another product called Screwwax sold by Woodcrafters and Amazon. Looks to be the same as Akempucky.
Howard
Thanks Howard, I just ordered me some Screwwax.
Chris
Bill CNC
Re: Screw Lube?
Post by Bill CNC » Tue Sep 03, 2013 12:50 pm
If, they are pre-drilled correctly, you should have little issues. If any further assistance is needed, as mentioned above, a bar of soap is the ticket.
Regards
Lowka53
Re: Screw Lube?
Post by Lowka53 » Tue Sep 03, 2013 7:09 pm
8) I have always used regular bar soap as bill stated also bees wax works as well. but the bar soap is the cheapest product to use. :wink:
14' Mr John-being built
32' Supper Huck-in design
Rod H
Old aussie
Re: Screw Lube?
Post by Old aussie » Wed Sep 04, 2013 2:19 am
I am with Bill cnc pre drill properly and you do not need to lube. your screw should only be cutting a thread in your timber not forcing
your screw in splitting your timber..
Old Aussie Peter....
Re: Screw Lube?
Post by kens » Wed Sep 04, 2013 2:43 am
Steel screws run into yellow pine with 'bar soap' lube corroded very badly, very quickly.
I avoid bar soap lube.
Bergy
Re: Screw Lube?
Post by Bergy » Wed Sep 04, 2013 4:18 am
Kens, I totally agree. Here is a good primer on wood screws that deals with all of the issues raised in this thread plus some.
http://www.diy-wood-boat.com/Wood_Screws.html
Howard
Abraham Lincoln
Bill CNC
Re: Screw Lube?
Post by Bill CNC » Wed Sep 04, 2013 12:28 pm
kens wrote:Steel screws run into yellow pine with 'bar soap' lube corroded very badly, very quickly.
Um, ... nobody said bar soap is a preservative for steel. Why anyone would use steel fasteners on a boat is a complete mystery to me. I wouldn't even use stainless fasteners that you cannot easily access for replacement, and yes, that includes construction fasteners buried in glue or under glass, ... but that's just me.
Bob Perkins
Re: Screw Lube?
Post by Bob Perkins » Fri Sep 06, 2013 5:46 am
Wax toilet bowl ring...
Holds the screws for you too. Works great..
Learned this trick at Wooden Boat School.
All I've ever used since.
Regards,
Bob Perkins
All the Fun Stuff
