Mr John
Lowka53
Mr John
Post by Lowka53 »
:) I picked up a set off plans for Mr John last year and did some of the framing. So this year I decided to put the boat together I ordered in the electric trolling motor to power her http://www.fingerhut.com/product//MinnK ... s?cat=8925 it should work fine until I can find a good used 9.9 to run her with. I am building a temporary covered building area to put Mr John together after that I will use it to put my Jubilee frames together the shop is taking longer than expected to get through the red tape here. The Mr John is one of the less documented builds it being of very easy construction but it does make a nice dingy for larger boats there is nothing fancy about the boat but a well used small work boat.
so here starts the build tread for my Mr John.
14' Mr John-being built
32' Supper Huck-in design
Rod H
thudpucker
Re: Mr John
Post by thudpucker »
Lowka that little boat would be just fine with 5.5-6 Hp.
A 9.9 is too heavy as well as almost TOO powerful for that little boat.
My opinions on these issues are based on lot's of terrible mishaps along the lifetime of learning what was the wrong thing to do! :lol:
Lowka53
Re: Mr John
Post by Lowka53 »
:lol: its rated up to 20 hp bud 8) Power: Oars or outboard motor to 20 hp.
Can the hull be extended or shortened? Yes. Up to 10% by re-spacing the stations a proportional amount. We do not recommend increasing the beam. per Glen-l :wink: but if you notice i have a 30 pound thrust electric trolling motor on its way for it :D the wrong thing to do would be for me to buy a guy i knows little 12' 1960 vintage utility with the 110hp tower of power he has sitting on it. I have thought of buying it just for the motor but it is a 2 stroker and there is talk of banding them in Utah. The price is right though i can get boat, trailer and motor for 300.00 :roll: the reason I am thinking 9.9 they are very common here and cheap to come by and are newer motors. :wink: and well under the rating Glen-l place on the boat. 8)
Rod H
BarnacleMike
Re: Mr John
Post by BarnacleMike »
I'm looking forward to following your build, Rod. I like Jon Boats. It's hard to find a more versatile boat in that size.
Last month I rented one with a 9.9 Yamaha in order to get the feel for operating a tiller-controlled boat... had never done that before.
Can't wait to see some pics of your progress!
Lowka53
Re: Mr John
Post by Lowka53 »
8) it has been awhile since I have used one but they are very versatile boats. For the time being it will be used to fish some of the mountain lakes. I like the fact they are pretty stable for their size.
Rod H
Lowka53
Re: Mr John
Post by Lowka53 »
:D Well my trolling motor came in to day and got a surprise it is being made for Johnson marine here is what she looks like
I was a little concerned buying a off brand until i seen who the distributor was :D :wink:
Rod H
BarnacleMike
Re: Mr John
Nice!
Lowka53
Re: Mr John
Post by Lowka53 »
8) I got some work done today i finished the building form which is nothing more than a 16ft x 4 ft leveled table
After the John Boat is built it will be used to put my house boat frames together they are 14 ft wide by 4 four deep. I still have to build a temporary shelter over the building table.
Rod H
Re: Mr John
Hey Rod, I'm glad to see that you can get some building in. Next to owning a cabin cruiser, I've kind of had a hankering for a smaller boat with a small outboard. Thanks for posting.
Lowka53
Re: Mr John
Post by Lowka53 »
mrintense wrote:Hey Rod, I'm glad to see that you can get some building in. Next to owning a cabin cruiser, I've kind of had a hankering for a smaller boat with a small outboard. Thanks for posting.
I had always planned on building this one it is to be the service boat to the house boat 8)
Rod H
Lowka53
Re: Mr John
Post by Lowka53 »
8) I picked up a portable garage to build in yesterday need to set it up now.
Rod H
Lowka53
Re: Mr John
Post by Lowka53 »
8) getting plans drawn for shop see viewtopic.php?f=2&t=10680&p=155980#p155980 for more detail
Rod H
Lowka53
Re: Mr John
Post by Lowka53 »
8) temporary garage is up. (My there must be a lot of unhandy people who reviewed this product they had all kinds of problems setting it up taking up to two days to put together I did it in a hour :lol:) I need to add lighting and cooling to it miner time problems easy fixed with a trip to the wallie world. Rested today due to a long with getting things set up I am working in my garden and getting the building site ready for the shop, I had two large tree stumps that need removed I was going to grind them out but opted on a cheaper method and burned them out. of course this is time consuming and as about as exciting as watching paint dry. but to save myself from the powers that be :( :? I had to over see the burn.but things are going slow. should be able to set up the building pieces soon 8) :wink:
Rod H
Lowka53
Re: Mr John
Post by Lowka53 »
8) I have gotten some work done I installed lights and ac unit in temp shop and proceed to start to put it together. Frames One and two are temporary and will be removed after the flip
frame two
Frame one getting all leveled and plumb
And the Bow piece
I dry fitted the chimes and should have no problem with the bends
Rod H
BarnacleMike
Re: Mr John
Woohoo!!! Off and running!
