Build the motor transom well. Should be in your instructions booklet. Mine was on the last page of it. I think that is all you will need.brad1516 wrote:thanks I was never going to take my chine off because the side planking was already planed and fitted perfectly I just have a sharper v nose and I added onto my chine and shaped it so my btm plywood has a good fastening spot thanks for the advice and the direction to go in. does anyone have any ideas on the transom I am putting a short shaft 35hp 2 stroke on it was going to make it stronger
Rabl Method
