Bullet
Sensless
Bullet
Post by Sensless » Fri Nov 07, 2014 3:16 pm
Hi guys I'm completely new to boat building, I have a good knowledge and enjoy building small projects but never have I attempted a boat, I'm already set on building the Bullet (not sure which length yet) but I was just wondering what anyone else has for engine power and how heavy the engine is, of course then how fast it goes, I would like a bearing on how fast this has the potential to go without scaring the living daylights out of me. So I guess the question is, How fast does it go on flat water?
Cheers
Re: Bullet
Post by hoodman » Sat Nov 08, 2014 7:45 pm
A 12' boat with 40 hp would definitely go fast enough to scare me. I bet close to 40 mph or more. If you look at the photos of the bullet someone claims 40 mph with 28 hp. I'm sure it will be a super fun boat if you decide to do it.
Sensless
Re: Bullet
Post by Sensless » Sat Nov 08, 2014 7:52 pm
Cool as, I'm hoping that'd be a fun time on the water
Mojo
Re: Bullet
Post by Mojo » Sun Nov 09, 2014 12:33 am
I'm getting close to 35mph with a 30hp on a 550lbs flying saucer. The bullet will be a fair bit lighter then this. She will be very fast for a little boat with 40hp. I'm guessing 50mph wouldn't be out of the question.
Cheers
Mojo
Scott
Re: Bullet
Post by Scott » Mon Mar 09, 2015 12:39 pm
Aristocraft Typhoon (12 foot version) with a 20hp Suzuki 4 stroke short shaft did 38mph with a full grown adult in it. Its a slender boat, but 200 pounds. The bottom says it all.
http://torontostar.newspaperdirect.com/ ... f3fe3ff72d
I know its not the answer to your question but gives you an idea.
Is the Bullet related to Swiztercrafts Bullet design?
Thun.der.bolt
ˈTHəndərˌbōlt
Sensless
Re: Bullet
Post by Sensless » Thu Mar 12, 2015 10:14 pm
That gives me a fair idea and i appreciate it, thanks for that :D
