Michael's ZIP
BarnacleMike
Michael's ZIP
Post by BarnacleMike » Sat Nov 29, 2014 8:45 am
I'm beginning to have enough ZIP questions that I thought I'd go ahead and separate this topic from my "Utility" thread. I've been looking forward to this for a long, long time.
I am still cutting frame parts, and I'm preparing to cut the side members for the transom frame. Fortunately, scrap pieces from Frame 5-1/2 were plenty big enough for these.
The instructions indicate to cut the transom parts at a 10° angle (angled away from the lines) on the outer sides, because the transom plans are drawn to the smallest (aft-most) dimension. It stands to reason that if I do this the same way for both the plywood part and the solid parts, I'll wind up with a "sawtooth" profile on the side when I assemble the parts.
SO: Assuming a 3/4" plywood transom, it looks like I should make my cut on the outer (side) edge of the frame members approximately 1/8" outside the line drawn on the plans, (again with the blade angled away from the line). I'll attach a graphic of what I'm basing this on.
Don't get me wrong— I'm not expecting these pieces to line up perfectly when I put them together. I'm just trying to get reasonably close. Does this approach make sense / sound reasonable to those of you who have actually built Zips?
Thank you!
Re: Michael's ZIP
Post by Bill Edmundson » Sat Nov 29, 2014 9:08 am
Michael
I would not fool with the 10 deg. cut. I would just cut the 3/4 ply an 1/8 over. Then cut the frame pieces 1/8 over and let it step. This can all easily be faired off.
Re: Michael's ZIP
Post by gdcarpenter » Sat Nov 29, 2014 9:39 am
Hi Michael, being the odd duck I am I used a 10 degree beveled router bit to 'fair' the sides of my transom, which was 1 3/4" thick solid white oak. If the final dimensions are 'off' 1/8" or so nobody will ever know, except you. I actually found the 10 degree side bevel a bit too much and couldn't get my hull side ply to take that much curve at the transom. Cuttin a bit big and fairing when you layout the hill side ply will likely work the best.
BarnacleMike
Re: Michael's ZIP
Post by BarnacleMike » Sat Nov 29, 2014 9:31 pm
Bill, did you mean cut the 3/4 plywood 1/8" over, and the frame 1/4" over?
Re: Michael's ZIP
Post by vupilot » Sat Nov 29, 2014 9:45 pm
Michael
I agree with gdcarpenter. The sides didn't take much angle to get a nice fit with the side planking. I bet mine are less than 10 degrees also. I would guess somewhere over 5 deg but less than 10. With that said though I just added about 1/4"+ to the outside of the transom sides and bottom and cut it with the blade straight then faired the aft edges to the angles needed during the fairing process.
CA
bjfrater
Re: Michael's ZIP
Post by bjfrater » Sun Nov 30, 2014 5:27 pm
I cut everything oversized on the outside edges by about an inch then attached the frames and the plywood together using temporary screws. Then I rough cut the bottom and the sides using a circular saw with the guide set at the correct angle. This removed most material and gave me a guide for fairing what was left, which was hardly anything.
It also ensured that the ply and the frames matched up perfectly.
BarnacleMike
Re: Michael's ZIP
Post by BarnacleMike » Sun Nov 30, 2014 7:03 pm
Thank you, Brendon. What spacing did you use on the floor battens, since you went with three per side? I've looked through the instructions for spacing on the 3-batten option, but I missed it if it's there...
bjfrater
Re: Michael's ZIP
Post by bjfrater » Sun Nov 30, 2014 7:21 pm
I will have to measure it when I get a chance tonight and will let you know.
I think I just moved the existing notches in the plans over by a couple of inches then added in a third one outside the first two.
There wasnt any specific location that I recall and I dont think it came from the book or plans. My battens are 2 1/4" wide as that was the best use of the timber I had.
One thing with my frames that I would do differently is to pre cut the notches in the frames for the chine and sheer as on the plans before putting them on the building form.
When I did mine I didnt cut the notches until the frames were on the form so that I could get the angle of the sheer and chine. I think this was not a good idea in hindsight as It was easy to cut the notches differently on each side which I then had to change.
Re: Michael's ZIP
Post by gdcarpenter » Sun Nov 30, 2014 7:45 pm
Hi Michael,
For what it's worth I went with 3 floor battens per side. I reduced the width of each batten to 1 3/4", but added stiffeners or strong backs that were 5/8" thick and averaged about 1" high lengthwise down the middle of all the battens. This allowed me to run my floor slats side to side using only 5/16" thick slats to seriously reduce the weight of the floor.
For the life of me I can't remember why but I suspect there was some reasoning for my batten spacing.
Measuring center to center my spacing is:
Keel to first batten 6 3/4"
First to second batten 5 3/4"
Second to third batten 6 3/4"
I have no way of knowing, but I suspect my 'extra stiff' floor allows me to reach 30 MPH with only a 1959 35 HP outboard.
Looks like you are making good progress!
Cabron
Re: Michael's ZIP
Post by Cabron » Sun Nov 30, 2014 9:26 pm
I`m with what the guys have said on this.
Cut the transom 1/8 outside of the plan line and the frame around a 1/4" outside the plan line
then just fair as required. I should have taken this approach but did not know better.
I fussed getting my transom and frame angles just right on the first cuts. I did it but it was a nightmare
trying to figure out the degree of flair out of the parts. The flair out of the notches was something else. That took some
serious head scratching. Fortunately it`s all behind me now.
I should have done the 3 battens per side. Oh well. I did not
Looking forward to seeing your ZIP progress.
bjfrater
Re: Michael's ZIP
Post by bjfrater » Mon Dec 01, 2014 12:50 am
Hey Michael, Lots of good advice here.
The measurements of my battens are from the centre of the keel to the centre of each batten 7 1/2", 13 3/8", 19 3/8".
Re: Michael's ZIP
Post by Bill Edmundson » Mon Dec 01, 2014 5:18 am
Mike
I just saw your follow-up question. Yes 1/8 over on the ply then 1/4 on the frame. This will give you a 1/8" step. You will fair off the step and trailing edge of the ply.
BarnacleMike
Re: Michael's ZIP
Post by BarnacleMike » Mon Dec 01, 2014 6:34 pm
Thanks guys. I just cut the side pieces 1/4" over. I like the simplicity of the "step-and-fair" approach.
BarnacleMike
Re: Michael's ZIP
Post by BarnacleMike » Thu Jul 07, 2016 4:41 am
Here are some progress photos of the Zip. I've got the transom frame members cut. They're cut from 4/4 mahogany and are 1/4" oversized on the outer sides and on the bottom. I did not try to cut the 12° bevel on the bottom... I'm going to step and fair that, as well.
progress on frame #4
Re: Michael's ZIP
Post by mrintense » Thu Jul 07, 2016 7:17 am
Looking good Mike.
Lots of interesting comments here. I see several things I could have differently. Oh well, too late for that now but I am looking forward to see what you do with the Zip.
Carl's Vera Cruise Build
