Michael's ZIP
Re: Michael's ZIP
That's a lot of clamps!
Re: Michael's ZIP
Keep it up, Mike!
BarnacleMike
Re: Michael's ZIP
Post by BarnacleMike »
Clamps removed, and fairing started. (Recommenced, really.)
I'm happy to say that all the scarf joints in both laminations of the port chine have worked just fine. If the laminations are thin enough (mine are 3/8"), they'll handle the bends and twists with no problem at all. I haven't had to soak or steam any of this, and so far nothing has broken in the process.
Re: Michael's ZIP
Post by neel thompson »
Looking really nice Michael
Re: Michael's ZIP
Good job Michael. I wish that I had used laminations on my chine. It would have been so much easier. I think I lost 3 months trying to correct problems that cropped up from using too thick of material.
BarnacleMike
Re: Michael's ZIP
It was SO much easier this way.
Gayle Brantuk
Re: Michael's ZIP
Post by Gayle Brantuk »
Really nice work, Michael. I like the way you did frame 5-1/2 and the stem/keel junction. I really wish I would have asked my dad why the Zip has frames 2, 4 and 5-1/2.
BarnacleMike
Re: Michael's ZIP
Gayle Brantuk wrote:
Wed Jul 31, 2019 9:00 am
Hi Gayle! Thank you!
I kind of figured out the frame naming a while back :) Here's the pull-quote from my blog about it:
At first glance, the Zip has some rather odd frame designations.... Specifically, frame number "5-1/2".
It seems odd until you understand that the designations are logically based on boat design drawings. If you look at a cross-section drawing of the boat, there are several vertical lines that divide the hull into sub-sections. Each one of these vertical lines is called a "station." The numbering starts at zero (the transom), and ends at "F.P." (which stands for "Forward Perpendicular") at the foremost tip of the boat. In the case of the Zip, there are 8 stations including "F.P.", dividing the hull into 7 sub-sections of about 24-1/2" each. Frame # "5-1/2" is the frame placed between stations 5 and 6.
Gayle Brantuk
Re: Michael's ZIP
Duh on my part! It shows that on the lines plan--thanks Michael.
BarnacleMike
Re: Michael's ZIP
Here are some photos showing fairing progress since the summer. It's coming along... slowly, but surely.
Chine at Frame #4:
Chine at Frame #2:
Chine at Transom:
Re: Michael's ZIP
Your experience and persistence shows, Mike.
Re: Michael's ZIP
Coming along fine Mike. I remember the fairing taking quite a while for me as well. I think you're attention to detail will pay off in good fitting skins when you get to them.
Evan
Re: Michael's ZIP
Post by Evan »
Nice work. I think on my next project I will be using the laminations like you have.
Antler24
Re: Michael's ZIP
Post by Antler24 »
Any updates on this one lately?
BarnacleMike
Re: Michael's ZIP
Nothing new at the moment. I haven’t touched it in a few months.
