Pee wee build in Sydney
chubs
Re: Pee wee build in Sydney
Post by chubs » Sun Jan 17, 2016 8:04 pm
Thanks Hz!
Bill that cartridge sounds great. Hope I can find it down here.
chubs
Post by chubs » Thu Jan 28, 2016 4:10 am
Getting the other side panel in position:
chubs
Screwed in partially:
chubs
Post by chubs » Thu Jan 28, 2016 4:36 am
Trimmed:
chubs
Post by chubs » Thu Jan 28, 2016 4:37 am
Lots more screws, not quite to the front, need to trim so the left and right sides don't foul. Angle grinder?
jenko
Post by jenko » Thu Jan 28, 2016 6:16 am
go for the multi tool
chubs
Post by chubs » Sat Jan 30, 2016 7:53 pm
Good idea jenko, wish I had one. Ended up abusing my grinder:
chubs
Post by chubs » Sun Jan 31, 2016 12:06 am
Screwed the other side most of the way, trimmed it, then screwed the rest. Paint will hopefully hide the screws!
chubs
Post by chubs » Sun Jan 31, 2016 12:07 am
And a close-up for good measure:
hzchevy
Post by hzchevy » Sun Jan 31, 2016 2:28 am
Don't worry about having to use the grinder. I built LIL INSANE entirely using a grinder ( with cutting discs, sanding discs ) and a small cordless screwdriver in a gravel driveway for most of it. Money was tight and I used what I had. Turned out alright.
Good job, keep going.
chubs
Post by chubs » Sun Jan 31, 2016 9:38 pm
Thanks hzchevy, glad I'm not the only one :)
chubs
Post by chubs » Sun Feb 07, 2016 12:03 am
Trimming the side so I can next do the bottom:
chubs
Post by chubs » Sun Feb 07, 2016 12:05 am
I used the planer this side, split the transom, aargh.
chubs
Post by chubs » Sun Feb 07, 2016 12:06 am
And the bow:
Post by DrBryanJ » Sun Feb 07, 2016 5:26 am
chubs wrote:I used the planer this side, split the transom, aargh.
I've done that. Try to keep the blade edge moving into the plywood. I mixed some epoxy and pushed it into the split laminations. I then stapled the plys together. Came out very strong. Done have any pictures, sorry.
