Pee wee build in Sydney
chubs
Re: Pee wee build in Sydney
Postby chubs » Fri Jun 19, 2015 6:02 am
This is how I measured for the angle to cut for the sheer to bend around:
chubs
Postby chubs » Fri Jun 19, 2015 6:04 am
Grooves cut ready for sheers. The jigsaw (new Bosch) died during, pity I lost the receipt:
chubs
Postby chubs » Fri Jun 19, 2015 6:06 am
And first lamination of the sheer is on:
Postby chugalug » Thu Aug 13, 2015 9:42 am
:D How's that little boat coming along? or did life get in the way?
chubs
Postby chubs » Tue Sep 22, 2015 1:47 am
Yeah life got in the way...
Finally got around to sawing off the chines and reposition them:
chubs
Postby chubs » Tue Sep 22, 2015 1:48 am
Also got busy gluing on the second lamination of the chine sheer (phew lots of jargon!)
chubs
Postby chubs » Tue Sep 22, 2015 1:49 am
Working from home for the next month so I'll be able to get some progress hopefully. Thanks for your interest.
Postby mrintense » Tue Sep 22, 2015 7:02 am
Looks good!
I must say, looking at your solution of getting to the sheers (i.e. turning the boat and building form over) gave me a chuckle. Your boat is so much smaller than mine. Adding my sheers was a real pain because of lack of space and the closeness to the floor Old knees don't bend so well)!
Very cool.
chubs
Postby chubs » Tue Sep 22, 2015 3:36 pm
Oh yes it certainly is easy to flip it over!
chubs
Postby chubs » Thu Sep 24, 2015 5:47 am
So next I have to fair it all. Any tips? I was planning on just going to town with my power planer and belt sander.
chubs
Postby chubs » Mon Oct 26, 2015 3:15 pm
All faired now, I used the planer mainly:
chubs
Postby chubs » Mon Oct 26, 2015 3:16 pm
What next? Paint the frame or attach the bottom ply first?
Also, how thick is the skin ply? I can't seem to find a number on the plans.
Thanks all
Ibrew2be
Postby Ibrew2be » Mon Oct 26, 2015 5:51 pm
chubs:
On a smaller sized boat such as yours, it likely doesn't make a lot of difference whether you paint the frames before or after doing the planking, though on the larger sized boats, the consensus seems to be to finish the frames first.
In terms of thickness of the plywood for the planking, it's likely quarter inch/6mm. I expect you received with your plans a set of instructions called "Building the Pee Wee". If it's like the instructions that came with my boat plans, on page 1 you'll find a Bill of Materials listed, and the BofM should list the thickness of the plywood used for planking.
Barry
Barry Shantz
Postby chugalug » Mon Oct 26, 2015 10:56 pm
:D If you paint the frames before putting ply on ,I'm not sure if you should coat the areas that gets glued to plywood(chines and shears and battons)It might hamper the glue joint-just my 2 wooden nickels.
Gayle Brantuk
Postby Gayle Brantuk » Thu Oct 29, 2015 8:33 am
The bill of materials is on page 5 in the instructions. The planking is 3/16" or 1/4". Looks great so far!
