Fairing questions
jeff k
Fairing questions
Postby jeff k » Wed Feb 18, 2015 9:25 am
Hello all,
I am building a squirt. I have frames assembled and keel and battens installed. When I start fairing, do I get my frames sanded out nice and then fair the battens to the frames? or do the battens stay slightly higher then the frames seeing that the hull material is not glued or fastened to the frames. Kinda scratching my head here.
This boat project is destroying my wallet, But it is enriching my soul.
Re: Fairing questions
Postby Bill Edmundson » Wed Feb 18, 2015 9:50 am
Jeff
I glue the bottom and topsides to the frames and battens. I put a row of screws to the keel, chines and shears. I usually have a few screws to the frames to hold the skin while gluing. But, NOT a row.
John K
Postby John K » Wed Feb 18, 2015 11:33 am
Jeff, Bill has it all summed up. Just make sure your frames are not higher than the battens. You want the "skin" to sit on the battens not frames. My frames and battens were the same height.
jeff k
Postby jeff k » Wed Feb 18, 2015 4:56 pm
Thank you to both of you.
