Prop Selection - redux
gdcarpenter
Postby gdcarpenter » Tue Mar 10, 2015 5:02 pm
Hi all, particularly Mr. Hot Rod.
Working on re powering my ZIP.
It currently has a 1959 Mark35A - 35 HP (@ the C/S).
With a brass - 10" diameter - 3 blade - 10" pitch prop, she runs a rock steady 30 MPH at a hair under 5,600 RPM.
Solo driver @ 165 LB plus boat a bit under 800 LB fully geared for a day on the lake. Final Gear Ratio is 14/23 and boat is 14'-4" long.
With a brass - 10" diameter - 3 blade - (with some cupping) - 9" pitch she runs 28 MPH @ 5,800 RPM with an amazing hole shot.
If all goes well the new/old engine will be a 1958 Mark58 - 45 HP (@ the C/S). I have 2 prop options at the current moment:
aluminum 10 3/4" diameter - 2 blade - 11" pitch
brass 10 3/4" diameter - 2 blade - 12" pitch.
Which do you think would be the best starting point?
The Mark58 is still 'a work in progress' but hope to "git 'er done" for this coming summer season.
Users browsing this forum: BarnacleMike, CaptDave and 8 guests
