Drain plugs
weasel
Drain plugs
Postby weasel » Wed Dec 23, 2015 5:38 pm
I am building the tunnel mite just getting started soon here. Does anyone know if it's safe to put a drain plug on the rear transom board towards the bottom? Will it weaken the boats strength or integrity any?
Re: Drain plugs
Postby gdcarpenter » Wed Dec 23, 2015 7:43 pm
Most put them in, none have sunk because of them, I chose not to put them in.
All the best!
jamundsen
Re: Drain plugs
Postby jamundsen » Thu Dec 24, 2015 6:02 am
I have two but that's because of the design of the interior
One should be fine
John Amundsen
Monte Carlo
Lakeland,Fl
Re: Drain plugs
Postby Roberta » Thu Dec 24, 2015 8:03 am
Safe to drill a hole through the bottom tramsom frame pieces on either side of the keel. Seal them up with epoxy and epoxy in a brass sleeve and use the expanding plugs.
Re: Drain plugs
Postby Hercdrvr » Thu Dec 24, 2015 9:42 am
Drill away brother, like ripping off a hand-aid.t The longer you think about it the more it hurts.
Re: Drain plugs
Postby Hercdrvr » Thu Dec 24, 2015 9:43 am
Band-Aid
weasel
Re: Drain plugs
Postby weasel » Fri Dec 25, 2015 11:02 am
Thanks everyone for the responses, great advice and good help with the photos
Re: Drain plugs
Postby chugalug » Fri Dec 25, 2015 1:17 pm
:D Also perhaps a small drain on each of the sponsons(I'm assuming this boat is a smaller version of the Tunnel King)Might be handy after removing from water and to drain water from hull.otherwise-a handhole and a sponge.or bilge pumps
