Tubby tug build
1Capperr
Tubby tug build
Postby 1Capperr » Wed Feb 03, 2016 9:42 am
Hi everybody, i an just starting a tubby tug build and haven't even got all my pieces cut out and already have a few questions. Do you stitch and glue your bulkheads and bulkwarks to your 1x's for your seat bases? I was also thinking of painting my bottom before i put my 1x’s on. Works it be OK to use top side paint for the inside of the hull?
Re: Tubby tug build
Postby DrBryanJ » Wed Feb 03, 2016 11:22 am
1Capperr wrote: I was also thinking of painting my bottom before i put my 1x’s on.
I don't really know the answer, but I think painting first might interfere with the epoxy bond. Maybe some with more experience with paint will chime in.
Also try posting your question in the paint section.
1Capperr
Re: Tubby tug build
Postby 1Capperr » Wed Feb 03, 2016 4:53 pm
You're probably right now that i think about it.
Re: Tubby tug build
Postby vupilot » Thu Feb 04, 2016 9:25 am
Welcome!
Yeah dont paint where epoxy needs to bond.
There are several Tubby Tug builders on the forum but in the mean time maybe Kevin's Tubby Tug build blog will help you out if you haven't already looked at it.... http://www.tubbytug.com/BuildPage1.html
1Capperr
Re: Tubby tug build
Postby 1Capperr » Thu Feb 04, 2016 12:40 pm
Vupilot, that does help a lot thanks
1Capperr
Re: Tubby tug build
Postby 1Capperr » Thu Feb 04, 2016 5:48 pm
So the only thing that holds the 2 bottom pieces together is the 1x's inside and the tape outside? I've looked at the plans to see if you stitch them together and haven't seen anything.
1Capperr
Re: Tubby tug build
Postby 1Capperr » Thu Feb 04, 2016 5:49 pm
So the only thing that holds the 2 bottom pieces together is the 1x's inside and the tape outside? I've looked at the plans to sew if you stick them together and haven't seen anything.
Re: Tubby tug build
Postby vupilot » Fri Feb 05, 2016 9:38 am
Although I don't have the Tubby Tug plans, yes, I believe that to be correct. Looking at pictures of other customers builds. http://boatbuilders.glen-l.com/tubby-tug-design/
The strength should come later from boxing in the aft end with the transom and seat box back there and the fiberglass tape helps too. Once epoxy bond is made the epoxy is stronger than the wood surrounding it.
