side skeg ?
greg mc
side skeg ?
Postby greg mc » Thu Feb 04, 2016 7:33 pm
how long ond wide are the rear side i think there splash gaurds i lilke the look but don't see many boats with it, any help would be nice , thanks Greg
Re: side skeg ?
Postby chugalug » Fri Feb 05, 2016 7:25 am
:D I used to have an old Dorsett Belmont fibreglass boat that had side spray rails in back.front of spray rail was about center of boat ,then flared out slightly all the way to the stern.and even incorporated the lift handles.there are images on web if you search "Dorsett Belmont boats"
Re: side skeg ?
Postby Bill Edmundson » Fri Feb 05, 2016 7:37 am
These are used on boats with tumblehome. That is the shear is smaller than the chine. They act as a guard at the dock by being a bumper/fender. The chine could bump the piling under water and be damaged. They start near the widest point of the boat and get wider as the side narrows. You would want the slightly wider than the chine.
greg mc
Re: side skeg ?
Postby greg mc » Fri Feb 05, 2016 9:05 pm
Bill Edmundson wrote:These are used on boats with tumblehome. That is the shear is smaller than the chine. They act as a guard at the dock by being a bumper/fender. The chine could bump the piling under water and be damaged. They start near the widest point of the boat and get wider as the side narrows. You would want the slightly wider than the chine.
thanks Bill, that makes since, the way the back is shaped. for some way i could not get that but the way you said that it make perfect since. Greg so they need to be what about an inch wider? then the wider part of the rear aft
greg mc
Re: side skeg ?
Postby greg mc » Sun Feb 07, 2016 8:52 pm
Any help on how wide and long and as to were to put it aft to center and what angle would be very nice thanks, Greg mc
rbrandenstein
Re: side skeg ?
Postby rbrandenstein » Mon Feb 08, 2016 8:55 am
Adding them is optional. I did not put them on my Malahini. I think location and size is up to the builder based on their aesthetic sense. The Glen-L plans may show them in a line drawing, but not really have details in the plans. You could estimate some dimensions from the pictures.
I believe Art Atkinson put some on his Squirt and he detailed the process in his blog. You can check it out here: http://artatkinson.blogspot.com/
________________
