Can this be saved?
Can this be saved?
Postby JimmY » Sat Sep 10, 2016 11:45 am
Hi All,
I'm starting my Squirt build and routing the notches for the battens and keel. The sapele is pretty nice to work with, but I think I tried to bite off too much with the router and the bottom of frame 1 split. This is actually my second attempt at this piece! Anyhow, can I use epoxy to repair this or should I start over again?
Re: Can this be saved?
Postby Bill Edmundson » Sat Sep 10, 2016 11:54 am
Jimmy
I think I would inject some epoxy and then clamp it and see how it turned out. Just clamp enough to close the crack. Nothing to loose.
Postby vupilot » Sat Sep 10, 2016 11:59 am
I agree with Bill. Belt and suspenders might be to add a piece of light ply to the inside face as a doubler. But I think getting epoxy in the crack and clamping alone will be sufficient. Carry on.
Postby JimmY » Sat Sep 10, 2016 12:35 pm
Thanks, I'll give it a try and see what happens. This second try used up my reserve of Sapele.
TAB
Postby TAB » Sat Sep 10, 2016 4:47 pm
you may also want to drill a small stop hole.
Postby kens » Sat Sep 10, 2016 5:11 pm
maybe break the crack all the way off, let it follow the grain, then glue up a good epoxy repair.
Postby Bill Edmundson » Sat Sep 10, 2016 6:53 pm
Ken may be right just go ahead and break it. Then you know you have epoxy in the whole thing.
Postby JimmY » Sun Sep 11, 2016 4:52 am
Thanks again for everyone's help. I'll try breaking it off completely before epoxying. I've got a bit more woodworking to go before I start gluing stuff together, so I'll set it aside for now.
Postby hoodman » Sun Sep 11, 2016 4:52 pm
You'll be the only one who knows it happened when its all fixed.
Nova SS
Postby Nova SS » Sun Sep 11, 2016 5:47 pm
I like ken's suggestion of finishing the break and then repairing it. If I didn't do that I would likely drill a small hole though the piece at the end of the split. the hole should stop the crack from growing then I would try to spring\pry the crack open slightly and force epoxy into it. Finely I would lightly clamp it so i didn’t squeeze out all the epoxy. Kens solution is simpler.
Postby JimmY » Mon Sep 12, 2016 9:04 am
Hi Guys,
I couldn't stand it and started epoxying a few parts together yesterday. I ended up breaking the piece all the way and gluing it back together. There was some splintering around the notch, so I mixed a little sawdust with the epoxy as filler.
After a little sanding, the results are pretty good.
Thanks again,
Postby JimmY » Mon Sep 12, 2016 9:05 am
The other side...
Postby hoodman » Mon Sep 12, 2016 9:52 am
Looks like the perfect fix. So far I have used wood flour as an additive when gluing. Sawdust is good too if it's fine enough. I had a big hole I had to fill in in one spot and mixed in a few shavings off of my hand plane to really bulk up the mix. There are lots of ways to fix things like this.
Postby Bill Edmundson » Mon Sep 12, 2016 9:59 am
What Crack? I don't see no damn Crack!
Postby DrBryanJ » Mon Sep 12, 2016 12:53 pm
If you don't point it out no one will see it. Nice job!
