Michigan Squirt Build
DSR
Re: Michigan Squirt Build
Post by DSR »
Hi Jim,
not sure if you will have this on your Squirt but the build plans on my TNT actually mention fairing (beveling) the keel area on frame 3 where it attaches (this is the frame that backs the stem on the TNT) to account for the curve the keel takes on fitting into the stem notch. I assume this is to straighten the keel out as it runs aft from frame 3 when installed. I hope that helps
Codename "Just A Little....."
viewtopic.php?f=23&t=29753
Keel and Stem
Post by JimmY »
Hi Guys,
Thanks for all the great input. I looked at the other thread and all of your posts and I think I know where I'm off a little...
Looking at the plans, it originally looked to me like the keel was flat from the transom to frame 2. But looking a little closer, there is a slight curve to it.
I double checked my transom, and you'll see that I had to shim it up a bit to get the keel flat.
Now if I clamp the keel to the stem, there is a slight bow aft of frame 2 and slight dip between frame 1 and the transom. But, I should be able to lower and adjust the angle on the transom so that the keel is flat from the transom to forward of frame 1 into the bow. The biggest problem is that I have to take off the transom to get at the screws for those shims, but that is better than trying to fair it out later. Using my long straight edge, it looks like I will only have to drop it an 1/8" or so.
Again, thanks for the quick and helpful responses!
BillW
Post by BillW »
That's a good idea to install the sheers before the chines. Otherwise you can't tell if the chines assume the right curvature
near the stem.
Also, do what it takes to make the keel straight; no dips or bumps anywhere in it's length. If you have to fair some off to
achieve that, then add a stiffener to the inside; I did that anyway.
It's looking good.
Sheers
Post by JimmY »
I was able to straighten out the keel Saturday morning and epoxied it in place before heading over to a friends house to watch Michigan beat State. Simply dropping the transom a fraction of an inch took care of it and the keel is dead flat from the transom to forward of Frame 1 and there is a gentle curve leading into the stem.
Between yard work and other duties, I was able to get the first lamination of the sheers on today. These are 5/8" x 1 1/4" Sapele, and I didn't need to steam or wet them down. I was able to screw them to the breast hook and slowly bent them around the rest of the frames. There was no snapping or popping! Score another point for Sapele. Also, I'm glad my building form is pretty sturdy as there is a lot of tension on these pieces.
I temporarily clamped them in place, and used a combination of rasps, chisels, and planes to adjust the notches to fit the curve of the sheer. I double checked the distance from my centerline to each sheer and fiddled until everything was within 1/16". Epoxy was mixed and now they are permanent.
Chines
Post by JimmY »
I started working on the chines, but the epoxy for the sheers is still setting up and I didn't want to disturb them. I did get them cut and fit into the transom and temporarily screwed to the transom and frame 1. Frame 2 is going to need major work to fit the notch to the curve of the chine.
DSR
Post by DSR »
Looks great Jim! I'm glad you got the keel straightened out, so to speak..... :D
rleete
Post by rleete »
Good progress.
Looking great! You're catching on fast!
BarnacleMike
Post by BarnacleMike »
Looking great, Jim! Congratulations on the progress!
Post by JimmY »
Hi Guys,
Thanks for the encouragement. I'm having fun and it was pretty crappy out yesterday so it was a good day to be in the shop.
Another question for other Squirt builders... On the plan there is line on the stem for the "chine" location. It doesn't say if this is the top, bottom, or actual break between the sides and bottom? I hadn't thought of that last option until I typed this question. The reason I ask is that when playing around with the chine, if it lays flat in the notch in frame 2, the twist is going to naturally put the chine almost at the breast hook and it will need to be bent up to hit the plan location. I've read that the chine location at the stem is a bit arbitrary, but I'm wondering where other builders have located it.
Benj269
Post by Benj269 »
I wondered the same thing, but making sure my breasthook was at the right height above the floor helped. After that it still seemed like they were about 2 inches away from the breasthook. I pulled mine down (up?) a little so it was 3 inches away. Any further and the joint at F2 starts to act a little weird and things don't flow correctly down the length of the chine.
Also, I did end up having to add some material to the outside of the last 12 inches or so of chine because they didn't bow out enough. It's difficult to judge until you get the sheer and stem somewhat faired.
I didn't notice the "Chine Junction" on the plans until you mentioned it. I'd have to measure, but I'm pretty sure even the bottom of mine is closer to the breasthook than that line.
Benj269
Post by Benj269 »
Yep, I'm way off. I think the joints at F2 have to be angled much differently than on the plans to be able to make a junction there.
A quick photoshop overlay
BayouBengal
Post by BayouBengal »
I seem to remember bending up on mine some to get it closer to the arbitrary point on the drawing, yet, in the end it fell a little closer to the breasthook.
Post by Hercdrvr »
Here's where I fit my Squirt chine. It looked sportier if I moved the junction slightly closer to the breast hook
Chines
Post by JimmY »
I finished adjusting the chine notches in frame 2 last night, and frame 1 looks pretty close and may only need minor sanding. I've got the first layer of chine clamped in place and wet them down with water and ammonia (old modeler's trick) last night to see if that will help them take a set. I think I'll also try wetting them and then taking a he gun to it. Sort of a poor man's steamer. I'm shooting for the top (er.. bottom) of the chine log to be just above the mark on the stem. I figure the mark is the actual chine line and that after fairing this will be close.
I've also got a bar clamp on the chine between frame 2 and the stem to help twist it. Glen L is asking a lot from this one piece of wood! :shock: I'm thinking of adding a chine hook to help take some of the forces of this piece per BillW's suggestion. If you have any photos of how you cut this and attached it, please post them.
Later,
