Reinforced transom
jno3441
Reinforced transom
Postby jno3441 » Wed Sep 21, 2016 4:44 pm
I recently read about a build of a zip. The guy reinforced the transom to accept a 25 horse. I was wondering if there is any certain way to do this.
I understand this may not be something that is commonly done or even recommended. I am merely curious about it as the zip will probably be my first build.
joshuab
Re: Reinforced transom
Postby joshuab » Wed Sep 21, 2016 7:43 pm
I am currently building a ZIP, it is rated up to 40hp with the transom as originally designed without any modifications, my plan is to run a 40hp, not sure where the "25hp" numbers came from but most zip builders are running 30+hp hope this helps.
Postby Roberta » Thu Sep 22, 2016 5:01 am
Installing the motor well will give the transom extra support. Also added two extra mini knees on battens outside the keel and some diagonal bracing. I ran a 50 hp Merc on my Zip. Also, use a transom saver brace when towing to relieve strain on the transom. Here are some pics of the motor well and bracing.
Moeregaard
Postby Moeregaard » Thu Sep 22, 2016 5:51 am
We've been running a 40-horse Mercury Mk 55 (~125 lbs.)on our Zip for eight years now. The transom and surrounding areas were built to the plans and we've had no problems. Adding a motorwell and surrounding deck obviously adds strength by "closing the box," but it's adequate as designed unless you're running a larger and heavier motor. As Roberta says, make sure you use a transom saver when the boat is trailered.
-Mark Shipley
Postby Hercdrvr » Sun Sep 25, 2016 8:27 am
Transom by design + motor well+ decking= plenty strong.
Mr. G L Witt knew what he was doing
