Pee Wee in Maine
283
Re: Pee Wee in Maine
Post by 283 » Sun Dec 03, 2017 7:06 am
Thanks JimmY. Hope to have it ready for Memorial Day.
Would there be any benefit or downside to adding intermediate lifting strakes or maybe a reverse chine strake/spray rail? Or both... I’m a little concerned about getting on plane with 5hp with both of us on board.
Mike
283
Post by 283 » Fri Dec 08, 2017 8:18 am
Mike
283
Post by 283 » Mon Dec 11, 2017 4:31 pm
Mike
Post by Bill Edmundson » Mon Dec 11, 2017 4:42 pm
Mike
Looks good! At this point make sure the bottom is good and flat the last several feet. It's easy now. It will be a PITA later!
Post by vupilot » Mon Dec 11, 2017 5:28 pm
You are making quick work of it!
283
Post by 283 » Mon Dec 11, 2017 7:49 pm
vupilot wrote:You are making quick work of it!
Hard part is waiting for the epoxy to dry. :wink:
Mike
283
Post by 283 » Mon Dec 11, 2017 7:50 pm
Bill Edmundson wrote:Mike
Thanks for the heads up... just checked it. One side is perfectly flat. The other has a dip of 1/8” or less over the last two feet... how much is too much?
Mike
Post by JimmY » Tue Dec 12, 2017 10:33 am
[/quote]
Thanks for the heads up... just checked it. One side is perfectly flat. The other has a dip of 1/8” or less over the last two feet... how much is too much?[/quote]
an 1/8" :D :lol: :D
283
Post by 283 » Tue Dec 12, 2017 12:26 pm
an 1/8" :D :lol: :D[/quote]
That bad, huh? :oops:
...to be clear this is what we are talking about :?:
Mike
Post by Bill Edmundson » Tue Dec 12, 2017 2:26 pm
Mike
As I said, easy to fix now. When you go to run it, and it starts porpoising it will be more work. You'll have to pull the engine, flip the boat, sand the paint off, fill the depression, fair, repaint, flip, remount the engine... Get the idea?
Post by hoodman » Wed Dec 13, 2017 10:45 am
I had the same type of "hook" on my boat. I was able to fill it with a fairing compound I made with epoxy and a mixture of microballoons and wood flour. I put packing tape on my four foot level to screed if off level. Let it cure and then long board sanded. It takes a little bit of effort but as Bill says, now's the time.
Post by JimmY » Wed Dec 13, 2017 5:22 pm
I second what the other guys have said. Much easier now. Later you are dealing with matching paint and polishing it.
283
Post by 283 » Thu Dec 14, 2017 5:17 am
No worries, was planning to fill it after Bill mentioned it... was just looking for how flat pretty darn flat needs to be.
Mike
283
Post by 283 » Thu Dec 14, 2017 9:04 am
Mike
Post by Bill Edmundson » Thu Dec 14, 2017 9:37 am
Mike
That looks easy enough. :D
