Pee Wee in Maine
283
Re: Pee Wee in Maine
Post by 283 » Thu Dec 14, 2017 1:49 pm
Bill Edmundson wrote:Mike
That looks easy enough. :D
Figured it was easier now then later :wink:
Mike
283
Post by 283 » Thu Dec 14, 2017 1:53 pm
Craigslist score for $35...
Not sure I’ll use the steering cable drum but I may. Honda does not sell a link arm or tilt tube for the bh5 that I have. So I’ll either have to make my own or go with pulleys.
Mike
Post by Bill Edmundson » Thu Dec 14, 2017 1:58 pm
Mike
Now you know that the bottom isn't the source of any performance issue. That gets you to engine trim or weight balance.
Post by 283 » Sat Dec 16, 2017 2:22 pm
Mike
283
Post by 283 » Sun Dec 17, 2017 8:18 am
Started sanding this morning... colored epoxy shows up every imperfection; ecspecially thr Black.
Still need some work especially the fiberglass overlaps
Mike
Steve-o
Post by Steve-o » Sun Dec 17, 2017 9:01 am
That Pee Wee is looking great I have been following this thread for a while and it gave me the courage to attempt my own build. I just bent my sheer and chine logs and am wanting to seal the frame before I put my hull on.
Did you seal yours? If so with what? Not trying to steal your thread. Keep up the posts please you are helping my a ton.
One more question what type of paint did you use on your hull?
Thanks again for all the information.
-Steve out of MN
283
Post by 283 » Sun Dec 17, 2017 10:08 am
Looks good Steve... That’s what these forums are for. See one, do one teach one :wink:
I plan on sealing or encapsulating the frames and interior hull with epoxy. Pretty much the SOP around here from what I gather. I didn’t epoxy all the frames yet. Just what I figured would be hard to reach after the flip as I had extra expoxy mixed.
No paint yet. I’ve been using tinted epoxy as I planned on a painted finish. The black is graphite added at 10% by weight. Which will be the finished surface for the bottom after another coat or two.
Mike
283
Post by 283 » Wed Dec 20, 2017 8:07 am
More sanding
Mike
283
Post by 283 » Sat Dec 23, 2017 7:39 am
...sanding...
Mike
283
Post by 283 » Sat Dec 23, 2017 7:43 am
Had my son do the rolling while I tipped with a cheap brush. He got a little bored halfway through and was a little ‘artistic’ on the top sides. Smoother it out the best I could :D May need moar sanding
Mike
283
The FLIP
Post by 283 » Sat Dec 23, 2017 7:46 am
Mike
Post by PeterG » Sat Dec 23, 2017 9:21 am
Looks great! And quite the work platform, puts the work up where you want it. That's going to be a fun boat for sure.
283
Post by 283 » Sat Dec 23, 2017 3:16 pm
Thanks Peter, it is very nice to have it at just the right work height.
hopefully Santa brings me some bow and stern eyes so I can get them installed so I can strap the boat down to the table. It’s a little wobbly as is.
Mike
283
Post by 283 » Wed Dec 27, 2017 11:26 am
After the flip I realized I forgot to cut limbers in the bottom of the battens :|
So I cut through th battens to provide a drainage path.
And I figured I should reinforce them. So I made stringers out 6mm ply and glued them in place.
Mike
283
Post by 283 » Wed Dec 27, 2017 11:28 am
I don’t have a pic but I also put sheets of foam for flotation on top of the battens between the stringers.
Mike
