Pee Wee in Maine
283
Re: Pee Wee in Maine
Post by 283 » Fri Jan 12, 2018 10:24 am
Got the seat boards made... going to try my own upholstery work. And the dash in place.
And then made some more shavings
Mike
283
Trying something a little different for the top deck
Post by 283 » Tue Jan 16, 2018 8:45 am
Cut some 3/8” ply into strips and will glue them in place and then fill the gaps with thickened epoxy.
Being 3ply the top veneer is 1/8” thick... figured it would save some time and materials vs gluing a veneer on top of 1/4” ply
Mike
Post by Jimbob » Tue Jan 16, 2018 9:55 am
Good idea!
I have never seen plywood that has a veneer that thick. What kind of plywood is that?
At my local hardwood supplier they do have sapele plywood. Found out too late. Maybe on the next boat. :lol:
283
Post by 283 » Tue Jan 16, 2018 10:41 am
It’s arauco ply. ACx. Goes for about $30 at Lowe’s.
I believe it’s radiata pine. The a sided is sanded. The c side has some plugs but usually no voids, closer to a b grade then most brands. I’ve never found a void in the core.
Mike
Mark-NJ
Post by Mark-NJ » Tue Jan 16, 2018 7:14 pm
You are moving at a spectacular rate of speed! Will this be on Androscoggin in August?
283
Post by 283 » Wed Jan 17, 2018 3:18 pm
Mark-NJ wrote:You are moving at a spectacular rate of speed! Will this be on Androscoggin in August?
Yeah we will be there weekends. And probably a week or two in august.
Mike
Mark-NJ
Post by Mark-NJ » Wed Jan 17, 2018 5:52 pm
Ice cream at Tubbys! I'll buy!
283
Post by 283 » Fri Jan 19, 2018 11:54 am
Sounds good, I never miss a chance for Tubby’s :D
Mike
283
Work on the top deck
Post by 283 » Fri Jan 19, 2018 1:19 pm
Lots of clamps and a few spring boards to get the last two boards where they needed to be
Mike
283
Almost ready for sanding
Post by 283 » Fri Jan 19, 2018 1:24 pm
Mike
283
Post by 283 » Thu Jan 25, 2018 1:44 pm
Mike
Post by Jimbob » Thu Jan 25, 2018 4:51 pm
Looks great!
I really like the contrast between the light wood and the dark caulk lines.
283
Post by 283 » Fri Jan 26, 2018 9:20 am
Thanks Jim, I had planned on getting some dyes and trying for a darker mahogany look. But after seeing I thought the contrast would work OK. I assume the pine will darken some with age.
Got the rest taped off and did the first fill. A 60ml syr8nge made it slightly less messy. It’s like working with roofing tar.
Mike
283
Post by 283 » Fri Jan 26, 2018 1:38 pm
Mike
283
Post by 283 » Tue Jan 30, 2018 4:24 am
Got started on the ‘cover boards’. Made a groove and started shaping the edges. Plan to paint once it is all filled and smooth.
Mike
