Squirt Finish Line
largej
Squirt Finish Line
Post by largej » Fri Feb 09, 2018 5:22 pm
Folks,
I am at the point where I need to decide how to fill in the seams on my deck. Mahogany perimeter boards with 1-3/4 white oak strip field. Seams are about 1/4 inch. I have read a lot of the posts on the forum and still can not decide. I am actually very nervous since this is kinda the make/break point of building project. I am looking at either the white caulking route or epoxy with micro balloons. Caulking route got good reviews from several folks here but the epoxy looks like it is the standard/preferred method. Deck is sealed with epoxy and ready for the seams to be filled - then I plan on several coats of spar varnish.
Any feedback on either method would be appreciated.
Thanks - Jim
Re: Squirt Finish Line
Post by JimmY » Fri Feb 09, 2018 5:54 pm
Hi Jim,
I wanted a smooth deck, so I went with epoxy and microballoons. This allowed me overfill the seams and sand them even with the deck. I just completed my Squirt back in September, so I can't say it will hold up over time.
The epoxy mix was pretty straight forward to apply once the deck was taped off.
Steve S
Post by Steve S » Sat Feb 10, 2018 8:23 am
Hi Jim,
I filled the seams with epoxy and microbaloons, also. But I added some white pigment to the mix.
The seams are holding up great and I have hit some hard waves with my Squirt.
How about a picture Jim? ?☺
Steve S
Squirt build
joshuab
Post by joshuab » Sun Feb 11, 2018 1:26 am
Wow there are more of us than I thought, I also used microballoons and epoxy to fill the seams on my zip, I too wanted the flush deck look plus I plan on top coating with Automotive clear coat and my thought was this would produce a more permanent seam, however I have yet to launch my zip so I cannot speak as to how it will hold up over time
largej
Post by largej » Sat Mar 03, 2018 11:17 am
Thanks guys for the info - very helpful. I am going to go with epoxy and microballoons. Looking at using a blank caulking tubes for application.One question/concern: I have several coats of epoxy on the cover boards and oak strips to seal and build-up a good base for the final varnish.
Do you think I should do a final deck sanding - to pre-varnish quality - before appling the epoxy in the seams? Or just wait because I will be sanding everything after the epoxy sets. Also, is there any chance I will get bleeding from the deck into the epoxy seams when I start to sand the epoxy? I am going with a flat/smooth finsh before I varnish. I am using painters tape to protect the deck while I apply epoxy. Here is where I am at so far:
Thanks for the feedback in advance.
Post by JimmY » Sat Mar 03, 2018 4:41 pm
Hi Jim,
You will probably need to sand down the micoballoons even with the deck, so I would wait to sand the deck until it is all flat. This will help prevent sanding through the epoxy on the deck. As long as you are using the same epoxy for the deck and microballoons, you shouldn't have to worry about bleed through. I would get the deck flat, and add a coat or two of epoxy to seal the caulk lines, sand, and varnish.
Make sure your varnish is compatible with the epoxy. Some here have used Epiphanes and it doesn't set up over epoxy.
Your Squirt looks great, the caulk lines will really bring that deck to life.
Post by hoodman » Sat Mar 03, 2018 5:51 pm
Great job!
Post by PeterG » Sat Mar 03, 2018 9:24 pm
Great job, your boat looks really sharp! I agree with JimmY about final sanding after filling the seams, you'll get a smooth deck for varnishing.
BayouBengal
Post by BayouBengal » Sun Mar 04, 2018 3:18 am
Looks like another beautiful Squirt will be on the water soon. Very nice work! :D
gap998
Post by gap998 » Fri Mar 09, 2018 12:56 pm
JIm,
Check out Josh's Youtube series - He has quite an in-depth explanation of the processes he tried on his deck before settling on the best method.
Gary
boat953
Post by boat953 » Mon Jul 02, 2018 3:08 pm
Hi,
I really like the style of your decking and wondered if you could give me some information on the practice of it and how it is best achieved, as I can seem to find any specific threads on this. I am also a new boat builder currently building a squirt.
Thanks
largej
Post by largej » Thu Aug 23, 2018 8:48 am
Folks - finished the boat and have been in the water and she is awesome. Still playing around with prop options but she handles great with the 25 hp and is solid; does get tossed around in chopping waters but then she is only 11'. Thanks to all the advise and info from you folks on the form.
Silly question - she is stored on the trailer, in my garage. Should I release the anchoring straps (bow and transom) while she is resting?
Biss
Post by Biss » Thu Aug 23, 2018 9:03 am
Really nice boat! I also really like the color scheme. I am planning to use similar colors for my Malahini.
Post by Jimbob » Thu Aug 23, 2018 9:21 am
She's a beaut!
Well done.
Post by Hercdrvr » Thu Aug 23, 2018 3:15 pm
Very nice Squirt....what did she run out at with a 25 hp?
