Marking zip chines for fairing
Cribbsy
Post by Cribbsy » Sat Feb 17, 2018 8:27 am
Hi guys, when marking the line for fairing on the chines between the frames should it be done with a continuous strip of timber the length of the boat to keep a clean line? I’ve done done it in two sections with a strip of mahogany but it doesn’t seem to hold its position well and looks a bit off
Re: Marking zip chines for fairing
Post by Bill Edmundson » Sat Feb 17, 2018 9:11 am
Cribbsy
I went to the box store and bought a piece of molding to aid in fairing, about 3/4" x 1/4" x as long as you need. I used this as an initial guide. Then, I fair to the eye. Finally, I use the molding to assure that it lies smoothly against the chine or shear. You can force it down some. Your checking that the planking will be in full contact.
DSR
Post by DSR » Sat Feb 17, 2018 11:48 am
Hi Greg,
Haven't seen ya in a while. Hope all is well.
Sounds like you're making headway on the Zip. That's great!! I'd love to see some pics (inserting subtle hint here... ) :D
Thanks;
Codename "Just A Little....."
viewtopic.php?f=23&t=29753
