Stephens Zip
sproggy
Re: Stephens Zip
Post by sproggy » Wed Aug 08, 2018 12:56 am
Roberta wrote:Wait on the notches until you are ready to lay in the shears and chines so you can angle them based on the direction that the longitudinals bend.
I think he meant the notches in the build form for frames 5 1/2 and 4. I just cut mine with a regular saw, slightly shallower than specified. Then final adjustments can be made with a chisel to get the frames exactly level.
Stevel
Re: Stephens Zip
Post by Stevel » Sun Aug 12, 2018 6:47 pm
I’m just about ready to order the plywood, do you all find an extra sheet or two extra sheets of quarter inch useful in case I mess up ? I’m having to get it shipped in so I’m going to order it all at once ..
It looks like I need around 10 to 12 sheets of 1/4 and 1 sheet of 3/4”
Re: Stephens Zip
Post by hoodman » Sun Aug 12, 2018 7:31 pm
I think it's not too bad of an idea to get an extra sheet if you are having to get them shipped. I have seen cracked sheets (mainly on the Malahini in the aft section). It would suck to have to order just one sheet.
BarnacleMike
Re: Stephens Zip
Post by BarnacleMike » Mon Aug 13, 2018 7:28 am
10 – 12 sheets seems like an awful lot for a Zip. Seems like I read somewhere that 7 sheets should cover it.
You should be able to easily get a transom and the stem/breasthook assembly from 1 sheet of 3/4".
I'd think 2 sheets should cover the side planking (1 sheet per side, cut in half lengthwise & joined).
3 sheets should easily take care of the bottom planking. A couple more sheets should take care of sub-deck and any remaining items.
I was expecting to order 7 or 8 for mine.
To answer your question, yes, I do believe it's a good idea to order 1 more sheet than you expect to use... just in case.
-Michael
Stevel
Re: Stephens Zip
Post by Stevel » Mon Aug 13, 2018 5:04 pm
As far as 1/4 goes
So looking at this bill of materials it looks like 8 sheets are required if I am reading it right .using 4x8 sheets ..I’m thinking I’ll order one extra sheet to make the gussets and one extra sheet as a back up
One 3/4 should be plenty
Stevel
Re: Stephens Zip
Post by Stevel » Mon Aug 13, 2018 5:09 pm
Eek shipping is $350 not fun!
Stevel
Re: Stephens Zip
Post by Stevel » Mon Aug 13, 2018 5:16 pm
Bill 3 should be plenty for bottom planking ? That would be great since it stated 14’ at 30” wide I was thinking it would need four
BarnacleMike
Re: Stephens Zip
Post by BarnacleMike » Mon Aug 13, 2018 7:26 pm
Stevel wrote:Bill 3 should be plenty for bottom planking ? That would be great since it stated 14’ at 30” wide I was thinking it would need four
I’m glad you posted the screenshot of the B.O.M. 4 sheets would probably be safest. I think your estimation of 8 sheets is about right.
Even before adding an extra sheet “just in case,” I believe you’ll have plenty enough scrap to make gussets.
What type of plywood are you considering?
-Michael
Stevel
Re: Stephens Zip
Post by Stevel » Mon Aug 13, 2018 7:30 pm
Sounds great, ill plan on ordering 9 sheets.. I am looking at hydrotek bs1088
either from here:
https://www.marine-plywood.us/mahogany_meranti.htm
or
from here:
http://houstonhardwoods.com/
BarnacleMike
Re: Stephens Zip
Post by BarnacleMike » Mon Aug 13, 2018 7:43 pm
The meranti from Homestead is exactly what I used on my Utility.
-Michael
Re: Stephens Zip
Post by hoodman » Mon Aug 13, 2018 7:56 pm
I think Meranti looks nicer but okoume is easier to work with. Meranti is very splintery.
joshuab
Re: Stephens Zip
Post by joshuab » Mon Aug 13, 2018 11:02 pm
I too used meranti/hydrotek, loved the look, i highly recommend using fine tooth blades in a jigsaw for cutting it, 36tpi or more, pretty clean cuts with those, i bought cheapie Ace brand blades, ran them till they started cutting slow then pitched them, they're cheap!
Re: Stephens Zip
Post by PeterG » Tue Aug 14, 2018 5:30 am
And precutting the face plys with a utility knife helps minimize splinter tear out. That trick worked great on my hydrotek meranti parts. It gave me a clean line to sand/trim to after cutting out the piece. Meranti is stiff but very strong, I recommend it for all the flat plywood pieces. Okoume is more flexible by comparison and works well for planking the hull.
Stevel
Re: Stephens Zip
Post by Stevel » Sun Aug 19, 2018 2:05 pm
Plywood is ordered , man that was a big first investment :shock: here we go!
Re: Stephens Zip
Post by hoodman » Sun Aug 19, 2018 8:05 pm
The plywood was the single biggest investment in my build not counting the motor. You'll have a lot to keep you busy now!
