Update time!
This was what I saw out of my window this morning.. a good 4" of fresh snow overnight.
Last week my step-father came out and gave me a hand making my building form. Good thing too.. because the night before I strained my left forearm and I couldn't even make a fist with my left hand... holding tools was a challenge and carrying sheets of plywood was not possible without his help. Thanks Jean-Rock!
As some of you know, due to the very dry conditions in Alberta I was very concerned about using studs for my building form lineals... over the winter and the dry heat I would be using in the garage heater they where bound to twist on me. So, I decided to build my own mini-lam beams using 3/4" exterior grade plywood. I cut 3pcs at 7" wide and 3pcs at 5" wide.. then I split one of each in half. Then I used scews to temporarily hold the 7" pieces together so I could notch a 7/8" x 2+" 'slot' to hold the frame.. then I glued, screwed, and nailed the 5" pieces to form the 'straight edge' that I would rest the frames on. I used a 6' level and clamps and bound them together. That was 2 weeks ago.
(End Cut-off of the mini-lam I built)
Then with my step-father, we put the masonry bolts in the concrete floor and built the building form and lined up and leveled the mini-lam beams.. worked out really well... very level, strong, and those notches hold the frames really solid and verticle.
Today, I centered Frames 1 through 4 on the forum, I started to brace frames 1 & 4 plumb... then switched to building up my transom and laminating my keel with plywood. My transom is going to be 2" thick... with 3/4" Mah + 1/2" DF + 3/4" Mah laminated to each other with epoxy. I used 2 cups of epoxy just to laminate the 3/8" ply to the keel and 1/2" DF to my 3/4" transom blocking.
I am almost out of epoxy... and I the local store has already shut down for 2 weeks. Its not cost-effective just to order 1 tin of epoxy from Glen-L with shipping.. so I am going to have to find an alternative supplier somehow if I want to work on the boat over the holidays.
Its great to see the frames layed out on the form.. you really get a good idea of the size. Its the perfect size.. for my garage and my family... only XXX months to go
