air file
Moderators: BruceDow, billy c
mickfly
air file
Post by mickfly » Wed May 16, 2018 12:43 pm
Another buildger told me he borrowed a pneumatic long board sander. Said it saved him hours and hours. I believe him...as I have a hand-held long board sander, which wears me out...and I found an Ingersoll rand 315 air file sander on amazon. Wonder if anyone has had any experience with an air file or pneumatic sander and has any advice?
jamundsen
Re: air file
Post by jamundsen » Wed May 16, 2018 2:38 pm
I used the Hutchins straight line sander. I can’t imagine sanding any other way. Have a good supply of air.i bought some cheap imitations first but soon threw them away.
John Amundsen
Monte Carlo
Lakeland,Fl
Re: air file
Post by Jimbob » Wed May 16, 2018 3:49 pm
I bought one from HFT - cannot recommend. Went back to sanding by hand.
Make sure that your compressor will provide the output for the CFM required by the tool. These sanders require a lot of air!
Re: air file
Post by billy c » Wed May 16, 2018 3:58 pm
jamundsen wrote:I used the Hutchins straight line sander. I can’t imagine sanding any other way. Have a good supply of air.i bought some cheap imitations first but soon threw them away.
John is correct on the Hutchins. Any cheap one ends up doing more harm than good.
Billy
Re: air file
Post by TomB » Wed May 16, 2018 4:34 pm
I'm using a Chicago Pneumatic. It works well.
Re: air file
Post by kens » Wed May 16, 2018 5:18 pm
phooey on the air file, worthless!!
Get yourself a 8" mud-eater.
It's a auto man's best tool for moving body mud, BONDO.
http://www.astrotools.com/air-tools/san ... 8-pad.html
that is a National Detroit clone.
The 900DA is the real McCoy:
http://ndsander.com/900-series/
I am a former body man, and I used both. When the 900DA came out, it immediately relegated the air file to holding the door open, it became nothing more than a door stop. On my build, I went so far as to get flooring sander belts, cut them up, and glue them on my 900DA.
Talk about moving wood on a 25'er.!!!!
With the 900DA, I also took sheets of wet/dry, glued them on, and wet-sanded with the 900.
jamundsen
Re: air file
Post by jamundsen » Thu May 17, 2018 1:22 pm
Hi Ken. I have one of those. I don’t have your kind of skills to use it. Even an idiot like me can use the Hutchins. Use whatever tool you are familiar with that does the job. I just can’t imagine how much work the hand sanders require. I’m just lazy.
John Amundsen
Monte Carlo
Lakeland,Fl
