It is currently Sat May 25, 2013 1:09 pm
Post new topic Reply to topic  [ 6 posts ]
PostPosted: Mon May 14, 2012 2:28 am
So, I repainted my trailer today and I have a complete suite of new keel and bow rollers
I also have two 8' treated 2x4s for bunks and new carpet.
I'm planning to cut the lumber to about 6 1/2' and line the rear edge up with the transom. Beyond that, it all guesswork.
Since I'm going with two bunks, I'm wondering where I should place them in relation to my battens; under the inboard pair or the outboard pair--split the difference?
I am also opting to place my boat directly on the trailer for top side finishing. This means I need the bunks positioned and angled correctly before I flip. I was considering getting a few helpers and setting the inverted trailer atop my un-flipped Zip to adjust the fit. Is this a good idea? Anyone have a better one? :?
Andy Garrett
"When all else fails, follow the instructions." -Dad
PostPosted: Mon May 14, 2012 7:23 am
If you are just going with two bunks you might consider at least 2x6 material. I'd go more outboard then inboard with them. It's also good practice to locate them under a batten.
For fitting you can get them close then block the boat up using some jacks and/or blocking material and fine tune the fit and location of the bunks.
http://www.unitybuild.net
PostPosted: Mon May 14, 2012 10:40 am
Andy, just a heads up for ya but the bunks on my trailer are 7ft and I dont think I would want them any shorter. Especially while you are fitting out the decks and interior, it can get nose heavy while working forward and want to tip forward on the bunks until you get the motor mounted. My bunks are about 13.5 inches from the center of the keel to the center of the bunk.
My Zip build log...
PostPosted: Mon May 14, 2012 9:48 pm
Thanks guys, maybe I'll extend the length a bit. Heck, maybe I'll add two bunks while I'm at it.
Andy Garrett
PostPosted: Tue Jun 12, 2012 5:42 am
Hey Andy, I used 4 bunks on my Zip. I made the inner ones 8 ft long and set them along the inner battens, The outer ones are 5 ft long and run along the chines. I used 5/4, 6" treated deck boards covered in 3/8" high density foam and heavy bunk carpet. Probably overkill, but the boat rides very comfortably on long hauls. I also added a roller near the front of the keel to keep the bow from going too low into the trailer up front. I made templates of the transom and #2 frame bottoms and used them as a guide to set the bunk angles. The 5/4 deck boards can flex a bit and conform to the boats changing shape very well. Once the boat was on the trailer, I could adjust the bunks up or down, via the slots in the brackets, to better fit the boat bottom.
Roberta :D :D
PostPosted: Wed Jun 13, 2012 12:42 am
Thanks Roberta.
I went ahead and bought more mounting brackets and set up four bunks. Two are 6.5 feet and two are 5 feet. Double layer bunk carpet on all top surfaces.
I also bought three new 10 inch keel rollers, a new bow roller and a spool roller for the stem.
I should be well protected.
Andy Garrett
