propeller
Boat trailers and trailering
cupper520
propeller
Post by cupper520 » Fri May 24, 2013 3:35 am
Is there anyway to make a jig to drill for a prop shaft.
Keith Easterday
fergal butler
Re: propeller
Post by fergal butler » Fri May 24, 2013 4:15 am
A lot of guys use the strut as a guide but as I didn't have a strut I had to work out the angle and where the hole starts on a jig I then marked out the angle on a block of wood and drilled a smaller hole to carry the drill bit extension bar and fixed it to the keel I also used a block to stop the drill bit from walking there is also a centre line marked on the keel so I can keep the drill lined up with it. Not the best way of doing the job but it worked for me :D
Mr Hot Rod
Re: propeller
Post by Mr Hot Rod » Fri May 24, 2013 10:27 am
We've compiled links to Glen-L Webletter articles about drilling the shaft hole on our website's Transmission Page. You'll also find a link to Dave Lott's article detailing his Riviera installation, our Shaft Angle Table and downloadable Excel Shaft Angle Calculator :
Hope his helps !
____________________
Paul Kane
Kane Custom Boats Ltd.
Chelsea, Quebec
