New trailer build
Boat trailers and trailering
dbug10
New trailer build
Post by dbug10 » Sat Apr 15, 2017 4:07 pm
Ok I am a newbie to this site and might I say it is an amazing and very informative site. I have a question about building a new trailer for my STV fiberglass 19' 3 sponson tunnel drag boat. The trailer it sits on now is a single axle C channel frame and I am wanting to build a tandem axle rectangular tube trailer and my question is this what size tubing should I use ? The current trailer is 1.5" x 4" C channel and I dont know if I shoud go with 2 x 3 or 2 x 4 tubing ? the boat is pretty light the hull all its contents and the outboard are between 950 and 1100lbs. I really think 2 x 3 x .125 would probably be what I would need but I am not 100% sure and would like some input from others so if anyone can give me some advice please do so
thanks
James Sanderson
Re: New trailer build
Post by hoodman » Sun Apr 16, 2017 5:52 am
I would get the book if I were you. Then maybe see if there is a trailer design in the catalog that will suit you.
http://www.boatdesigns.com/mobile/How-t ... fo/12-432/
Nova SS
Post by Nova SS » Sun Apr 16, 2017 7:50 am
Yes Glen-l has several different trailer sizes you can choose from I am sure one of them will be perfect for your boat.
rleete
Post by rleete » Sun Apr 16, 2017 8:20 am
At 1/8" wall, 2x3 would be plenty strong enough.
I just designed a waste water tank stand for work, and used 2x2 tubing with .090 wall thickness. That tank holds over 500 gallons.
Post by Bill Edmundson » Sun Apr 16, 2017 9:10 am
Are you looking at aluminum or steel? If I was home I could compare the choices. For a tandem trailer you will need very light springs.
TAB
Post by TAB » Mon Apr 17, 2017 3:12 pm
personally I would go with 4.
you will find that a lot of stuff is made too go on 4" c channel. so things like tire holders and jacks can be installed easily.
Jester97
Post by Jester97 » Thu Jul 26, 2018 5:30 am
Any update on this build?
