well the spit would not work with a 14 foot beam and a 10 foot ceiling height lolchugalug wrote:Not going to try the"turkey on a spit "trick.Where's your sense of adventure?
I used come-a-longs hung from ceiling rafters but would have worked better with floor jacks.
Building underway for the Jubilee
Re: Building underway for the Jubilee
14' Mr John-being built
32' Supper Huck-in design
Rod H
Rod H
Rod H
Rod H
It would be if I had another it is 165hp motor when I checked into power they stated a Michigan motor i would need a single 350 cbi min. to power the size of the jubilee. The bayliner I got in the spring does have a out drive merc A1 that was linked to a V-6 but the screws are both the same direction. I going to part out the bayliner it needs much more work than the Olympic to get back in the water. I will use it to fish the local lakes until I can get the Build done or at least until I get to the point of putting a motor in the build. And it snowed this morning
I got to get the boats covered for winter now I can't put it off any longer
Rod H
Rod H
