no more porpoising
BruceDow
Re: no more porpoising
Post by BruceDow »
Again, Dave... thanks for exploring this for us.
I recall that your porpising (like mine) was sensitive to the passenger load. (For me, three in the front and no-one in the back was my best performance at high speed)
Do you find that with the shims the performance is smooth across a variety of passenger loads? Or does it still vary with different weight distributions?
Thx.
B.
Bruce.
Dow's Monaco Project
DaveLott
Post by DaveLott »
The only passenger I had was my wife and I had her move around from seat to seat and to the back. There was no affect to the performance.
But I do believe I am a little aggressive with my angle at this moment. I am going to reduce down until I feel she is just balance right for these conditions:
2 people in front= 400#
fuel tank of fuel on transom = 170#
swim platform hanging off transom= 70#
and going 50mph.
I want to bring the angle down so that I can get to this speed under these conditions without any porposing in different types of seas.
I will have a full load in the rear compartment next week when I go on a fall color cruise about 80 miles up the lake. I will have the angle down to 3/8" and see what happens and report back to you
Glen-L Sea Kayak
Mahalo Standup Paddleboard
Video of Midnight in Action
I'd love to see a new picture at speed. I want to see the boat attitude compared with the before pictures! I think, I'm a little bow down. But, I don't bounce.
Even with a full load you were beaking the water about 18" to 24" behind the helm seat. Most "classic" boats seam to break the water right under the seat. I think mine is 8" to 12" forward.
This not from knowledge. Just looking at the boats.
DaveLott
Post by DaveLott »
Bill Edmundson wrote:Dave
Agreed. Right now I am breaking just forrward of helm seat. I am riding low. But definitely was riding high
Glen-L Sea Kayak
Oyster
Post by Oyster »
http://www.grand-chronicle.com/
page 9
Midnight Cry brought tears of joy to those that saw her.
upspirate
Post by upspirate »
I see there was another boat built from a "kit" there!!!!
DaveLott
Post by DaveLott »
upspirate wrote:I see there was another boat built from a "kit" there!!!!
That boat was ACTUALLY built from a kit. It is a James Craft.
I was the only handcrafted boat at the show.
The boat next to mine (the Hackercraft Gentlemen's racer) won the Contemporary award.
Glen-L Sea Kayak
sschefer
Post by sschefer »
I realize this is the most cost effective solution for you but have you thought about prop styles. A prop with better stern lift often overcomes bowlifting without need to add hook at the stern. The reason I mention it now is because you've found the problem and to that there is more than one solution.
Steve Schefer
Santa Rosa, Ca.
New Years Resoluiton - Never leave something for someone else to do when I should be doing it myself.
BruceDow
Post by BruceDow »
Thanks for adding that.
I have also been porpoising at my high end. I have not yet added shims. I have been investigating "prop rake" to see if that would make a difference. My prop appears to have a slight positive rake. I have been advised that a neutral or negative rake should reduce bow lift/increase stern lift.
I guess I need to talk to a "prop shop" expert to see if we can try some out and see if they make a difference.
Bruce.
DaveLott
Post by DaveLott »
Interesting point. I had planned to go to our local prop shop next week regarding prop sing. Above 32mph, the prop sings a very merry tune until about 40. Since I like to cruise in the mid thirties I get the consistent ringing in my ears.
We will report back on this. This shop is regionnally known as the best so we will find out
dave
Glen-L Sea Kayak
GLH
Post by GLH »
Dave, here is a shot of the gentlemans racer that was next to your boat. I think this is the one you are talking about???
Post by PeterG »
Dave, I read earlier about your prop singing and I wonder if your running a bit too much blade loading? Check out David Gerr's propeller handbook and you'll see that a prop with a bit too much loading could suffer this singing effect. Ask about a prop with a higher Disk Area Ratio, which essentially means same diameter and pitch but each blade has more surface area with a stronger blade root at the hub, and a reduced tendency to vibrate. Also, check out Michigan Wheel's web site where they give a good description of propeller characteristics.
garrys
Post by garrys »
Dave, did you lay a straightedge on the bottom of your boat, fore and aft? Did the straightedge indicate anything other than perfectly straight (flat)? I remember the building instructions for my Monaco emphasizing that the bottom of the boat be perfectly straight for the last 5 feet or so, and also that the transition of the bottom to the transom be as "sharp" an angle as possible. A rounded corner will cause porposing. I don't have that problem with my boat, but then the only storage available on the Monaco is under the front deck, where I keep my anchor, chain, mooring lines, life vests, fire extinguisher, fender bouys, and beer cooler, so I've got quite a bit of weight up there to keep the nose down. Interestingly, I was at a water ski tournament this past weekend where I saw a 20' outboard with twin 300HP engines. The owner told me he had to put 300 pounds of lead in the nose to keep the boat from doing wheelies!
DaveLott
Post by DaveLott »
Garry. My bottom is true and the transom edge sharp. The alignment of the keel, strut and rudder are dead on. Everything is the way she supposed to be. I also thought about some sand bags up front as well.
But this is working so well, I am just going to dial it in with the correct size and leave it alone.
Yes, I have heard about some of those guys talk about getting weight way up front. That is maybe why I wanted to use Warren as a hood ornament.
dave
Glen-L Sea Kayak
DaveLott
Post by DaveLott »
GLH wrote:Dave, here is a shot of the gentlemans racer that was next to your boat. I think this is the one you are talking about???
Yes, Gary, that is the one that won the best contemporary award. I believe it was built in 98 by Hacker Company.
Glen-L Sea Kayak
