It is currently Sat May 25, 2013 11:27 am
Post new topic Reply to topic  [ 446 posts ]  Go to page Previous  1 ... 18, 19, 20, 21, 22, 23, 24 ... 30  Next
PostPosted: Thu Apr 19, 2012 4:24 pm
WOW!!! That is really nice!!!!
Roberta :D :D :D :D :D
PostPosted: Thu Apr 19, 2012 5:09 pm
Very nice :D
I Peter 2:17
PostPosted: Thu Apr 19, 2012 6:08 pm
the "Grizzly Grip" makes a real difference....where I put it on the inside of the bulwarks....its almost impossible to see the edges of the cloth. it really blends everything in....it looks like it was sprayed
I'm quite pleased with the results...... preparation is the key!!! the areas not painted will be painted after I get all the floor supports, and the tanks and cabinets laid out....
I have to go north for a couple of weeks...so it should be fully cured....(as if its not already)
I'll be in myrtle beach for a week...relaxing on the ocean !!!
when we return I'll finish up the bilge pumps/ battery trays/battery wiring...and maybe hang the motor.....then re-assemble the cabin framing.....
Wayne
PostPosted: Thu Apr 19, 2012 6:26 pm
8) Looking good I like the use of Grizzly grip it should give some water protection
14' Mr John-Wild Flower 2
Rod H
PostPosted: Sat Apr 21, 2012 10:27 am
Wayne,
Been reading my plans, now I'm more confused, but going to purchase floor lumber. I forgot what thickness and kind you used.
E-Mail your number again please, Thanks
Jack
PostPosted: Tue May 01, 2012 5:03 pm
I was in upstate ny last week...picked up a bunch of old oak..baseboard/window mouldings that I can clean up and use to make my rub rails, and cabin trim.....between the oak I got while there in December....and this trip I should have plenty....my next project is to build a steam box...to steam it to bend around the stern.....I'll get that started next week, along with some basic wiring and plumbing before installing the rear sole.....W.
PostPosted: Thu May 03, 2012 1:03 pm
I posted a few of the latest pix on facebook last night.....when they are displayed on a full screen,...the grizzly grip.....is very evident...checl it out...W.
PostPosted: Mon May 07, 2012 7:18 pm
I'm back from the north, and back to work today...started to run electrical wire/hook up batty cables..deciding final location of fuel and water tank...bought a used frig. today and think I'll add it to the port side....wired up to an inverter....
We intend on using this boat !!!!
wayne
PostPosted: Tue May 08, 2012 4:19 am
I don't see your face book page listed :? :roll: :wink:
Rod H
PostPosted: Tue May 08, 2012 6:06 pm
I got power wires run thru the chase tube, along with stern lite power and bilge power wires. now starting to tie wires together as needed/where needed....tomorrow I will figure out balance of floor and fuel and water tank locations.....I'm not trying to rush things...but am getting excited, as every day it looks more and more like a real boat.......!!!
PostPosted: Wed May 09, 2012 5:55 pm
today I finished the supports for the sole..in the cabin...installed the steering cable, and the shift and throttle cables, all under the rear sole...soon I will be re-installing the motor, and hooking-up everything....starting the cabin sole tomorrow....Wayne
PostPosted: Fri May 11, 2012 3:14 pm
today I finished the starboard side of the cabin sole.....ran the lead for the depth finder/gauge...have to drill mtg holes for the sole, and then on to the port side sole...took a couple of pix....but left camera at the shop....oh well !!!!!!!!
PostPosted: Sat May 12, 2012 7:02 pm
Wow ,all this work is making me thirsty!!! :wink: :lol:
PostPosted: Mon May 14, 2012 6:36 pm
here is a little bit of info for those out there building the tugg-along.........when you build your floors for the inside in the cabin.....you have to cut shims to fill the gap between the floor panels, and the longitudal reinforcements.....you want the floor to be level.....as there is a natural curve to the bottom of the boat....so this has to be compensated for..........Wayne
PostPosted: Tue May 15, 2012 5:53 pm
today I managed to finalize my floors in the cabin...and the location of the water tank and fuel tank....I picked up a small refrig..so that goes on the port side opposite the porta potty....I re-installed the cabin sides today....so have to square up and level everything...then add the roof section, and trunk cabin roof......before I put the roof on I will frame it up for a fantastic vent...and install the roofing/cloth epoxy...as it will be easier to do on my work table rather than up in the air....to be continued....Wayne.
Users browsing this forum: Bing [Bot] and 4 guests
