Huck Finn 20. Transoms
jeffmo63
Re: Huck Finn 20. Practice scarf joint
Postby jeffmo63 » Mon Sep 01, 2014 3:56 pm
Spent the last few days making big wood into small wood. Pic is of materials kit for one pontoon. Left to right are sheer members, keels, and chine logs.
Jeff Mo
jeffmo63
Re: Huck Finn 20. Materials kit.
Postby jeffmo63 » Thu Sep 04, 2014 5:29 pm
The stem assembly after the first coat of Poxy Shield
jeffmo63
Re: Huck Finn 20. Question on transom thickness?
Postby jeffmo63 » Fri Sep 05, 2014 11:14 am
It is quickly getting to be that time to build the transoms on my Huck Finn 20. As most of you know I am building a tri-toon configuration with an outboard motor mounted to the center pontoon. The plans do not detail this installation. What transom thickness is recommended for a 25-40 horsepower motor? I was thinking between 1 and 1 1/2 inches would do. Also, what type of reinforcing do I need between the transom and the sides? Any thoughts or ideas would be appreciated.
Jeff
jeffmo63
Postby jeffmo63 » Wed Sep 10, 2014 8:15 pm
I found the answer to my question on page 66 of my "Boatbuilder's Notebook." Thanks Glen!
jeffmo63
Postby jeffmo63 » Mon Sep 15, 2014 10:13 am
Well, here it is; more merranti plywood and douglas fir from Boulter Plywood. On to scarfing!!!
Team-M2
Re: Huck Finn 20. More wood; on to scarfing!!!
Postby Team-M2 » Thu Sep 25, 2014 5:14 pm
Jeff,
Your "little" project is looking pretty good. Looks like the spring of 2015 will involve the maiden voyage!!! :D No pressure...
Enjoy your project and hope to see you soon!!!!
Michael
jeffmo63
Postby jeffmo63 » Mon Sep 29, 2014 8:34 am
You make me laugh so hard Mike! I'm trying to get a last push in before the cold weather sets in. The epoxy doesn't do well once the temperature drops.
jeffmo63
Re: Huck Finn 20. Three stems complete
Postby jeffmo63 » Thu Oct 16, 2014 2:02 pm
Pic is of the three completed stem assemblies. They have one coat of Poxy Shield on them. They will get an additional coat. Next; mounting one of them to the building form.
jeffmo63
Re: Huck Finn 20. Three completed stem assemblies
Postby jeffmo63 » Fri Jun 05, 2015 2:03 pm
Today I cut out the trasoms. There is a lot going on back there but careful study of the plans should provide some clarity.
Grand Chillin
Postby Grand Chillin » Sun Jun 07, 2015 3:14 pm
Jeff,
Glad to see you are back to work on your Huck Finn!!!
jeffmo63
Re: Huck Finn 20. Transoms
Postby jeffmo63 » Tue Aug 25, 2015 9:00 am
Here is what the transom frames look like. They overhang the plywood transom slightly so that a 6 degree angle can be cut,
jeffmo63
Postby jeffmo63 » Mon Aug 31, 2015 9:04 am
The transom frames are glued to the plywood. I used countersunk #8 x 3/4 bronze screws instead of nails.
jeffmo63
Postby jeffmo63 » Mon Apr 24, 2017 4:16 pm
My first completed transom. It took a lot of time and study but I finally got it done. Next step; attaching the stem, bulkheads, and transom to the building form.
Users browsing this forum: Bing [Bot], chugalug and 8 guests
