It is currently Tue May 21, 2013 2:26 pm
Post new topic Reply to topic  [ 98 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 7  Next
PostPosted: Sat Dec 25, 2010 11:24 am
Here are some of the first parts we made. In this case, the bow uprights were ripped out of 1 x 6 Douglas Fir. Note the bottom ends are not squared to 90 degrees. They're closer to 96 degrees.
PostPosted: Sat Dec 25, 2010 10:37 pm
Jeff,
I picked up on that too and still don't know why it is needed. Unless I missed something. :shock: :roll:
PostPosted: Sun Dec 26, 2010 8:42 pm
My sidekick "Smiley" pouring over the plans.
PostPosted: Wed Dec 29, 2010 9:51 pm
Transferring cardstock template of stem to 2 x 8 Douglas Fir.
PostPosted: Sun Jan 02, 2011 8:21 pm
Pic is of the two stems that have been cut out of 1 1/2" Douglas Fir. Note fairing lines.
PostPosted: Sun Jan 02, 2011 8:30 pm
Jeff,
I pre-beveled the stem as per plans on the first frame, but I didn't on the next two stems. It seemed to work better that way. I did make the lines for reference when attaching the sheer and chine.
PostPosted: Sun Jan 02, 2011 10:36 pm
Thanks Chip, I was kinda wondering about pre-beveling and I may hold off. What did you use for most of your fairing work? A plane? Disk sander? Other? I am currently working on 5 horses to get my form up off the ground per your suggestion. Really cold in the workshop. Pic is of forward gussets and uprights.
PostPosted: Sun Jan 02, 2011 11:44 pm
I did most of my fairing with a 3" x 18" belt sander and finished with my 5" orbital sander. I only used my electric planer on the keels between the stem and next frame because there was more material to remove. Keep in mind I didn't use DF so experiment with what tools you have and find what works best for you. You will not regret moving the form up.
You still haven't told us where you are located. Post it in your profile.
PostPosted: Mon Jan 03, 2011 8:09 pm
I've updated my location in my profile. Pic is of the cross members of the form supports (saw horses). Hard work!
PostPosted: Mon Jan 03, 2011 11:09 pm
Jeff,
That is exactly how I built my horses. An i-beam with the legs connecting right under the top 2x4. Amazingly strong. Heck I have 4 pairs now and one pair in the works. :D
PostPosted: Fri Jan 07, 2011 10:02 pm
My Mom bought me a plane for Christmas. Be careful. They remove a lot of wood quickly. The saw horses are nearing completion.
PostPosted: Mon Jan 10, 2011 2:10 pm
The five saw horses I built. These will be used support the building form.
PostPosted: Fri Jan 21, 2011 10:42 am
Saw horses anchored to floor. Next is square and level. Pic taken at 0 degrees F.
PostPosted: Fri Jan 21, 2011 11:00 am
Jeff,
I love the comment about the weather on your pic... Why, it looks nice and sunny to me! :D
Malahini Build Gallery:
http://picasaweb.google.com/11229065623 ... directlink
PostPosted: Sun Jan 23, 2011 9:20 pm
Onplane, I checked out your build gallery. Some beautiful work and helpful photos!
