I guess it's time to come out of the closet!Bartender 24
Re: I guess it's time to come out of the closet!
Post by kens » Mon Mar 14, 2011 4:39 pm
That is a cool boat, Bill.
Post by Bill Edmundson » Mon Mar 14, 2011 6:46 pm
After I encounter a few flying bridge sport fishermen, I wanted something up to 4' wakes. This thing sea trialed in 15 to 25 foot breakers.
Right now, her name is "Frances (Blue Butterfly) Lauren". My mother died in June 2010. Her estate will pay for it. I told you the Butterfly story. The Lauren...
Oyster
Post by Oyster » Mon Mar 14, 2011 6:55 pm
Okeedokie, now we are talking.. Have you gotten the well area figured out?
DaveLott
Post by DaveLott » Mon Mar 14, 2011 7:01 pm
Bill Edmundson wrote:Dave
Fantastic - I suspect she is smiling down on you right now.
Glen-L Sea Kayak
Mahalo Standup Paddleboard
Video of Midnight in Action
Post by Bill Edmundson » Mon Mar 14, 2011 8:10 pm
Mike
I think I've got the well. With the engine down I can make lock to lock, I can tilt normal trim and I can tilt all the way up to clear the bottom. This boat has a fold down plug that fills part of the well when running. This increases the planning area.
leakcheck
Post by leakcheck » Mon Mar 14, 2011 8:59 pm
That's an ugly boat ! Good thing you have a good looking wife to compensate for it ! :roll:
(Looks like it can go as fast backwards as forwards)
Grand Chillin
Post by Grand Chillin » Mon Mar 14, 2011 9:23 pm
Man, I was scared to check out this thread after reading it's title. :shock: Bill just don't open that other door. :roll: :wink: :lol: Thanks for sharing. That is a cool boat. 8)
Oyster
Post by Oyster » Tue Mar 15, 2011 7:31 am
Bill Edmundson wrote:Mike
I have not seen the plans with the setup. But a raw and blunt edge of the filler may not be the best. I would think that the style that leans towards that would catch and throw water straight up too or even be ripped off of the brackets when it gets rough and catches the water. Do you have a scan or something showing the leading edge?
Post by Bill Edmundson » Tue Mar 15, 2011 8:45 am
The plug is somewhat of a box which goes from the bottom to the waterline and is foam filled. The leading edge is about 30 degrees to the bottom.
I'll see if I can get the scan to post.
Click the drawing. The green box behind the engine is the plug.
Oyster
Post by Oyster » Fri Apr 01, 2011 6:59 am
Bump! Upates?
Post by Bill Edmundson » Fri Apr 01, 2011 7:09 am
:lol: Well... I layed the keel last weekend. And I have started the frame to frame filler pieces which support the self bailng deck. I'm putting those in to stablize the frame spacing before I do the chine. I hope to work on the chines next weekend.
This weekend I'm away for the build and I'm going to play with the Tahoe.
Post by Bill Edmundson » Fri Apr 22, 2011 5:55 am
Been kinda slow going with traveling/work and time playing with the Tahoe.
The chine is 7/8" x 2 3/8" white oak. It really did not want to take this bend. I'm still working on it. This weekend I'll steam it all again to try to stess releave it some more.
You can never have too many clamps.
You always need the type clamp that you don't have!
Yes that is a curve in the keel.  The first layer, underneath is straight.  Most of the layer you see will be faired off.
Post by Roberta » Fri Apr 22, 2011 6:44 am
Looking Great, Bill!!! Isn't it amazing how creative we get when we need to accomplish something!! That's the fun and what keeps us going.
DaveLott
Post by DaveLott » Fri Apr 22, 2011 9:30 am
Dang - I wish I was back in the shop building like that. :mrgreen:
Glen-L Sea Kayak
Oyster
Post by Oyster » Sat Apr 23, 2011 6:56 am
Of course you do know that if you just rip the hard ends into smaller strips and reglue them, that the chines are still sound and structual even if you do this at the ends. I cut a small angle say five degrees on the slices and this allows the chines to go back together locking the strips in place until he glue takes up. I place a waxed paper or plastic tape strip across the faces as I rebend them and clamp them across the tops and bottoms so they do not pop back up as I bend them in place. Of course the thickened glue needs to be more than a slurry mix so that it stays put. This is my well boat with the wharped bottom.
Generally speaking even though this may not apply to what you end up with, the shape will be a bit rounder than a forced and targetted heated board thats too big for the continous bend and curve that the wider plywood planking takes too. So be mindfull not to create a flat spot when you plank the sides if the chines are not uniform in their curves. Some can also be pulled out too depending on the thickness of the sides. Of course you can also backfill and leave until cured some excessive thickened epoxy and not clamp the parts together if you find the need to do so.
