Riviera powered by v12 jaguar
Mr Hot Rod
Re: Riviera powered by v12 jaguar
Post by Mr Hot Rod »
Now that's a nice piece of work !
Do you have a final weight figure for the drivetrain and do you have a photo of the shaft log ? It must be a tight fit !
____________________
Paul Kane
Kane Custom Boats Ltd.
Chelsea, Quebec
jenko
Post by jenko »
Engine ,trans and vdrive are 340kg , have yet to add trans and engine oil cooler , exhaust logs and water pump.
jenko
Post by jenko »
Have been motivated by the gathering but lots of head scratching . finished my deck framing moved rear cockpit back 4 inches after determining fuel tank dimensions and ski pole location as well as seat dimensions and other various bits and pieces , so many thing to think about before making a decision .
Decided not to alter the deck camber and go with a hatch scoop and a couple of clam shell vents aft.
Iam having trouble with the seat framing the plans mention dimensions but I can't seem to find them any suggestions ?
Aussie
Post by Aussie »
Peter,
Looking great and good progress...the scoop looks a good shape......i on the otherhand havent done much at all..will get into it over the next few weeks.....
Jamie
jenko
Post by jenko »
After a bit of a spell and much head scratching over internal layout have a few more pics to post.with seat layout and mockup fuel tank made fitting to hold gm in tank pump and fuel sender
jenko
Post by jenko »
I have been working on my exhaust logs. Hot rod asked me to post some pics of the process
jenko
Post by jenko »
what appeared to be a simple job has been quite tricky as the stainless pipe shrinks as you weld it the first one had to be adjusted a bit but second one I can allow for the shrinkage and should make a neater job
vettepilot
Post by vettepilot »
Looks Great!! Hope to see it in the flesh so to speak...one day. :D
steveh41
Post by steveh41 »
Ditto! :D
hcraft
Post by hcraft »
Great job, interesting to see someone else putting a Jaguar V12 into a wooden boat, as you and I know there are not many bolt on parts available.
billy c
Post by billy c »
pretty looking work Peter! will be one of a kind :D
-Billy
Post by kens »
WoW!! That looks great.
Where did you get the center riser exhaust manifolds?
jenko
Post by jenko »
centre riser manifolds are nice,but would be to high for my application, what boat is your motor going in?
hcraft
Post by hcraft »
This is the Nelson Zimmer that I built in 2001 to 2005 that will get the V12. There are far more photos of the Jag motor build on my "H Craft" face book page if you have access to that.
H
Mojo
Post by Mojo »
H Craft, that looks incredible. What model of Nelson Zimmer is it?
Cheers
Mojo
