Riviera powered by v12 jaguar
Grae1
Re: Riviera powered by v12 jaguar
Postby Grae1 » Thu Sep 22, 2016 4:20 pm
Looks awesome Pete! Love the interior. I am using Boatcote products too, so I'll have to remember your experience with the clear coat when I finally get to that stage.
Adrock1
Postby Adrock1 » Fri Sep 23, 2016 5:35 am
Absolutely spectacular. Just beautiful.
jenko
Postby jenko » Fri Sep 23, 2016 3:30 pm
Thankyou all for the compliments ,still going on the interior finished the helm and glove box next to seat only the rear seat side panels (or are they called ceilings) and speakers to go
Postby Roberta » Fri Sep 23, 2016 4:11 pm
Nice !!!!!
Roberta :D :D :D :D
sscobra
Postby sscobra » Fri Sep 23, 2016 9:33 pm
Beautiful!! Hope my upholstery comes out that nice. Skip
jenko
Postby jenko » Tue Nov 08, 2016 1:24 pm
some more photos
Postby Roberta » Tue Nov 08, 2016 1:31 pm
Beautiful.
steveh41
Postby steveh41 » Tue Nov 08, 2016 1:32 pm
Beautiful pics Pete... she sits perfectly on her lines! Which lake are you on? Reminds me of Northern California foothills :D
sscobra
Postby sscobra » Tue Nov 08, 2016 11:02 pm
Stunning boat in beautiful scenery!!! Skip
jenko
Postby jenko » Tue Nov 08, 2016 11:29 pm
thanks Skip ,Roberta and Steve ,
It Is lake Talbingo part of the snowy hydro scheme .largest dam built in Australia 4,780 acres average depth 280 ft.
Only road access is either end ,28 miles long ,so it is a very pristine lake
Dave Grason
Postby Dave Grason » Wed Nov 09, 2016 4:47 am
I found the lake on Google Maps. It is long and narrow. It really does look remote which makes it my kind of lake. We certainly don't have many like that here anymore. Here is the link:
https://www.google.com/maps/place/Talbi ... 2118?hl=en
etswaterride
Postby etswaterride » Fri Nov 25, 2016 8:53 pm
Very desirable....incredible!!! If I have anything like these boats on this forum when I am done I will be one happy dude!
While gazing at your pics I fully understand the goal of a natural finish!
jenko
Postby jenko » Mon Dec 12, 2016 12:45 am
Thought I would post a slip graph of my current prop which shows some very average performance which is why I am going to change it
The prop I am running is a 12 x 15 supercup with 10 deg aft rake 3 blades with 1.14:1 gear ratio
as the graph shows it is not really planing till 2700 engine rpm,
which is a bit fast for the learner skiers .
So my aim is plane earlier and cure porpoise above 5600 rpm, and better slip figures.
So I have changed gear ratio to 1.03:1 and a 12 x 12 cupped prop with 6 deg aft rake and 4 blades .
fingers crossed :roll: I shall post results
jenko
Postby jenko » Mon Dec 12, 2016 9:59 pm
tested prop all good except above 4000 rpm where it just slips, did every thing else I wanted so cant tell if it cured the porpoising ,anyway prop shop says they can tweak that.
Postby kens » Tue Dec 13, 2016 6:52 pm
Something doesn't seem quite right,
Did you get WOT with either prop?
Your graph ends at 5400rpm, but where did you experience actual WOT?
Your second prop, you say it did everything you wanted, but,,,,,,,prop shop can fix it.
Fix what?
Fix the porpoising, or fix the slip?
The slip on the second prop makes no sense, because as speed goes up, the prop area needed goes down. (somewhat)
you added the 4th blade in this case and you say slip went up. Im not buying it without better data.
How were both props measured for size? The same prop shop measured both, with the same equipment?
Or, did you use different prop, with different prop shop, with different equipment, with different technician?
