Doing IT ! / Little Hunk
jamundsen
Re: Doing IT ! / Little Hunk
Postby jamundsen » Thu Sep 01, 2011 2:58 pm
Nice shelter and the frame looks good too.
John Amundsen
Monte Carlo
Lakeland,Fl
Seiner
Postby Seiner » Thu Sep 01, 2011 10:04 pm
Looking good Mike! You have to be excited!
here is what it looks like closer to the other end. first coat of hull paint and three primer coats.
svenole
Postby svenole » Fri Sep 02, 2011 7:18 am
Yes i am :!: your boat looks GREAT ! :!:
svenole
Postby svenole » Mon Sep 12, 2011 12:14 pm
Im taking my time ,transom done and i had to make a new stem.i messed it up when i tried to bevel it on my table saw.i glued and screwed it to the first frame.i work the next 7 days but i have a little time before work.leveling frames and lineing them up .i have 2 that are alittle off >the side frames i mean>> sanding will do the trick. :D
svenole
Postby svenole » Thu Sep 22, 2011 3:50 am
hi,i mounted tHe transom but i didnt cut the angle yet .whats the best method for doing this :?: :idea: .its to long for a tablesaw.maybe mount a long board on the back of transom thats cut at the angle and use A handheld circle saw? and go slow :!: !i wouldnt have to cut it all at once just alittle at a time. oh yeah its framed also >so ill be cutting 3/4 in. ply and 1 in. white oak.>mount the board >use it as a guide and cut :!: :?: :idea:
svenole
Postby svenole » Thu Sep 22, 2011 4:13 am
:?: or clamp 2 boards one inside one out and sand ,plane down to them :!: :idea: :?: im going to work on it all day.i also need to bevel the Stem.
Oyster
Postby Oyster » Thu Sep 22, 2011 4:19 am
The skilsaw is the way to go with the transom laying flat on some sawhorses or table with it hanging off. Just cut it a bit wild and then when you place it back on the strongback you can refine it with a grinder or belt sander when you get it set to the angle that you need or like.
svenole
Postby svenole » Thu Sep 22, 2011 3:54 pm
Im planeing it>slow is good :!: :D
svenole
Postby svenole » Sat Sep 24, 2011 7:42 am
Im going to have to plane the transom sides a little so planking lays flat, have not seen that in te plans.
Postby billy c » Sat Sep 24, 2011 8:11 am
...just part of the fairing process so not noted specifically
svenole
Postby svenole » Sat Sep 24, 2011 9:07 am
OK , i was thinking that.ive got a nasty storm going on >ill have to wAIT :!:
svenole
Postby svenole » Wed Oct 05, 2011 12:31 am
Man ! im anal ! im too worried about screwing up ! have too move it ! transom is notched and i was trying to make the frames vertical.by useing some long scrap wood and finish nails to hold them straight up. that didnt work after an hour of getting pissed >then i layed my keel in the transom notch>>>>>>>GAA why didnt i do that first :!: :?: :roll: worked great! i October already ! the thought of snow makes me nervous :!: i wanted to get the hull done and sealed before that>we shall see !
svenole
Postby svenole » Fri Oct 07, 2011 5:10 pm
Frames vertical and battons going on, >>>>>>>>>>>>ill finish on sat.!: i still need to bevel the frames >so they lay flat. later
Oyster
Postby Oyster » Fri Oct 07, 2011 5:47 pm
You are making progress even while the winter season is creeping in on you. Good job.
svenole
Postby svenole » Fri Oct 07, 2011 5:50 pm
Thanks ,Oyster :!: ill keep pushing :!: :D
